View Full Version : $8.88 - Brake Caliper Decals
8th Day
03-01-09, 06:49 PM
The Finishing Touch
http://8thdaycreations.com/catalog/images/Vlogocaliperdecals.png
*V-series set pictured; CTS set also available.
CLICK HERE (http://8thdaycreations.com/catalog/product_info.php?products_id=33) for details, color options and ordering information.
https://www.paypalobjects.com/WEBSCR-560-20090225-1/en_US/i/bnr/horizontal_solution_PPeCheck.gif (http://8thdaycreations.com/catalog/product_info.php?products_id=33)
Cut from premium automotive grade vinyls that have been tested to adhere to aluminum with no ill effect from -58 to 230 degrees and are resistant to most oils, greases, and fuels. The decals also come on clear application paper for easy installation.
jweymar
03-01-09, 07:15 PM
cant order them
LUVMY04V
03-01-09, 07:30 PM
i need another set of these just for good measure Goth I sending u a pm :cool2:
8th Day
03-01-09, 07:49 PM
cant order them
I've sent you a PM.
If anyone else encounters a problem using the 8th Day site, please send me a PM here or an email to administration@8thdaycreations.com . Thank you.
LUVMY04V
03-01-09, 07:59 PM
rofl!!!!
http://8thdaycreations.com/catalog/product_info.php?cPath=22&products_id=53
rjoffe
03-01-09, 09:49 PM
230 degrees just won't cut it.
Vecstasy
03-01-09, 10:16 PM
Just curious. Are these the exact same size as the Decals that are on the calipers stock?
gothicaleigh
03-01-09, 10:35 PM
They're going on the outside of your caliper, not your rotor.
For an idea on caliper heat levels, most caliper seals need to be replaced if they exceed 240 degrees (not to be confused with rotor temps, which can easily climb to double that).
The decals are tested to adhere to bare aluminum (which is a very slippery metal) with no ill effect up to 230 degrees. Trust me, if your caliper becomes hot enough to melt off the adhesive on these, you will have more things to worry about than your decals.
8th Day
03-01-09, 10:49 PM
They will. We've installed them on cars that have seen fairly heavy track use and sold many other sets online (including to members here) and have never had a reported failure.
We use only the finest automotive-grade vinyls available.
Each set comes with three different sizes (8 decals total).
4 @ 3.000" long
2 @ 4.000" long
2 @ 2.500" long
