View Full Version : I need the measurements of the specter bushings please
ctsv154
03-01-09, 10:28 AM
All I need is the ID of the ring, OD of the ring and the height of the ring. Just act like it doesn't have two little ears on it and its just a piece of pipe or something.
http://i150.photobucket.com/albums/s88/specterwerkes/cradlebushings.jpg
darkman
03-01-09, 10:42 AM
I have a new set in transit to me and can tell you when they arrive (next week presumabley) if someone else does not report in first.
ctsv154
03-01-09, 11:19 AM
That would be great! I'm buying some delrin stock off ebay for cheap. I'm going to use just the rings and fill the fill the voids with with some stuff called flex 80 putty or some stuff called flexane 80 putty. Pretty much the same thing just a different brand. I have the rings with the kars kit but dont like the way they fit. I saw a pic of the specters installed and they look like the fit very well so that will take some of the pain out of crawling under the car and measuring everything.
Thanks
atdeneve
03-01-09, 02:02 PM
Har jou go:
Small Bushing
• 6.2 cm ID
• 7.6 cm OD
• 1.2 cm height
Large Bushing
• 7.2 cm ID
• 8.6 cm OD
• 1.2 cm height
ctsv154
03-01-09, 04:14 PM
Thanks!
I was at Steve's Wholesale tools and found some black urethane I might try. It was a lot cheaper than the flex 80 stuff. I'm going to see how hard it gets.
