rellsun
02-28-09, 07:35 PM
I have a 1994 Cadillac seville with a 4.6l v8 northstar and the engine went (head gasket leak) and was wandering if a can swap it out with a 1993 deville 4.9l v8?
| View Full Version : Swap 4.9l v8 and 4.6l v8 northstar rellsun 02-28-09, 07:35 PM I have a 1994 Cadillac seville with a 4.6l v8 northstar and the engine went (head gasket leak) and was wandering if a can swap it out with a 1993 deville 4.9l v8? Ranger 02-28-09, 08:15 PM No. Different trans. Different PCM. Probably motor mounts and other things I'm not thinking about. Destroyer 02-28-09, 08:33 PM Dude just get another car. CaptainFishpond 02-28-09, 11:05 PM Drop in an LT1! Highline Cady 03-01-09, 02:41 AM Why why why if your going through the hassle of switching to a different motor would you ever pick a 4.9? Swap a fwd Impala SS running gear, it'd probably be easier. Personally just stick another N* in it and do basic maintenance and you probably wouldn't be in this situation to begin with. pimpdaddycaddy91 03-01-09, 12:29 PM I think that it would be possible but it would be alot of work and you would run into alot of problems. I think that it would be less work to fix the Northstar. If your up to swapping engines out then you should be able to tackle the HG. I just finished my first HG/headbolts project, biggest job I ever did but I finished it and it works! even with a few extra bolts left over lol. That always happens to me. Dont get me wrong I love the 4.9, it always amazes me how much power it has and it will run to 200,000+ miles with no major problems unlike the Northstar HG. The problem is the 4T60E that it is mated to. You will go through 2 of them for every 4.9 engine. AJxtcman 03-01-09, 01:40 PM I have seen a lot of 4.5L & 4.9L Head Gasket failures, so what would the advantage be? rellsun 03-01-09, 01:47 PM Well i was going to have a friend do the work and he said its best to get a rebuild or one in good running condition instead of getting a junkyard one. so i saw a 1993 deville with a 4.9 on craigslist for 600 compared to 1000-2500 for a junkyard or rebuilt motor. Anyway didn't think it would work but doesn't hurt to ask. | |
