View Full Version : Installing B&M and Need Help!
blaausl10
02-27-09, 01:32 PM
I have the old shifter out and am starting to put the B&M in. The question I have is what parts do I use when putting it back together? I don't have the original instructions so I'm not sure what every part is. Here is a picture of everything that came with it. Please help!
http://i295.photobucket.com/albums/mm155/blaausl10/P1000475.jpg
BacDoc
02-27-09, 01:51 PM
IIRC you use the bottom left steel piece, cap the ends with the top right plastic end caps, slide the top center cylinder through, insert into shifter cable, insert bolt through, tighten, replace boot and knob. The other pieces are for the CTS I believe.
Also while you're at it, replace those 2 bushings on the shifter slide with the UUC poly's and be happy.
rand49er
02-27-09, 01:53 PM
PM sent.
blaausl10
02-27-09, 01:54 PM
Thats what I was thinking. Used the rubber mallet for a little convincing. Thank You!!!!
