: 1990 Cadillac Brougham 5.7
DPOWELL14
02-14-09, 01:59 PM
The problem started with the car acting like it was starving for fuel. Thought I might have got some bad gas so I added some lucas fuel additive. After a few more attempts to get it to run it wouldn't start at all. Had to get a tow truck to get it home. I have since replaced the tps and the map sensor. Still will not run. The only code I get is -00 I32. I am at a loss what to do next. I can't take it to the shop as I can't get it to run. Any suggestion's?
csbuckn
02-14-09, 02:07 PM
Are both injectors spraying fuel? Did you ever get it to start after you put the lucas in there? If its getting fuel, next would be spark. How are those plugs doing?
jayoldschool
02-14-09, 02:16 PM
If you can't see fuel coming out of the injectors when you crank, I will bet it is the fuel pump. Of course, check the fuse and the relay first.
DPOWELL14
02-14-09, 02:19 PM
Yes i am getting fuel and spark.
csbuckn
02-14-09, 02:19 PM
I dont know how I forgot the pump, being I just replaced mine in the beginning of winter.:cookoo:
sven914
02-14-09, 06:02 PM
The problem might be that your getting too much gas. Check the pressure regulator and see if is leaking into the throttle body.
mjs182004
02-16-09, 12:57 PM
or you may not be getting enough gas, maybe replace the fuel filter.
