AJxtcman
02-12-09, 01:56 PM
Hey guy's I have a new project.
An 06 STS engine with a 07 E67 STS PCM in a 57 Chevy.
I will get some pictures up soon. :D
| View Full Version : 06/07 RWD STS Engine and Trans in a 57 Chevy AJxtcman 02-12-09, 01:56 PM Hey guy's I have a new project. An 06 STS engine with a 07 E67 STS PCM in a 57 Chevy. I will get some pictures up soon. :D CaptainFishpond 02-12-09, 02:08 PM Wow, pics soon please! AJxtcman 02-12-09, 02:13 PM Big mistake on my part. This is an STS-V engine and trans from an 06. :thumbsup: WOW CaptainFishpond 02-12-09, 03:30 PM Even better. Much better. AJxtcman 02-12-09, 07:33 PM Wow, pics soon please! I need to ask if I can post them. submariner409 02-12-09, 08:21 PM This is a Northstar tuning forum...Why not ??? We now need to get into a FWD - RWD distinction, because the two drivetrains are as night and day when it comes to mods and maintenance. dkozloski 02-12-09, 09:04 PM One huge benefit is that there is no excuse for not having a real exhaust system with a RWD insallation. AJxtcman 02-12-09, 11:22 PM http://i224.photobucket.com/albums/dd25/AJxtcman/57%20Chevy/Picture_019_sized.jpg http://i224.photobucket.com/albums/dd25/AJxtcman/57%20Chevy/Picture_2979_sized.jpg Highline Cady 02-13-09, 02:05 AM What are you up to... Didn't you tell them your still working on a Ford!!! LOL AJxtcman 02-13-09, 07:47 AM What are you up to... Didn't you tell them your still working on a Ford!!! LOL It isn't like that. :alchi: The car won't run. I need to dissable the "VATS" and turn off some other items to get them going again on the build. I will be doing either another "Tune" for them on that PCM or they will send me a second one to spend some time on. :thumbsup: Highline Cady 02-13-09, 08:01 AM Does look like a sweet project. That's the blown 4.4? Are they swapping in engine and trans? May as well swap the heated seats also.:D AJxtcman 02-19-09, 02:52 PM http://i224.photobucket.com/albums/dd25/AJxtcman/57%20Chevy/57engine2.jpg http://i224.photobucket.com/albums/dd25/AJxtcman/57%20Chevy/57engine.jpg AJxtcman 02-19-09, 09:57 PM The first tune out to get the guy going. The car won't run with out the VATS disabled. Main File : 57 STS-V Original.bin Compare File: 57 STS-V.bin Main File Parameters : 473 Compare File Parameters: 473 Parameters Compared: 456 Differences : 17 Operating System General LS2 VATS Patch 1 Enabled : Disabled LS2 VATS Patch 2 Enabled : Disabled Engine Airflow Electronic Throttle Area Rate Limits Throttle Area Increase Rate Fuel Control Fuel Cutoff, DFCO RPM Limits RPM Limit Extreme Resume 6500 : 6600 rpm RPM Limit - Spark Disabled : Enabled COT, Lean Cruise CAT Over Temp Protection CAT Over-Temp Enable Enable : Disable Torque Management General Traction Control System TCS Limit - Spark Enabled : Disabled TCS Limit - ETC Enabled : Disabled Delivered Torque Max 424 : 2424 ft.lb Powerhop Master Enabled : Disabled Powerhop - Spark Enabled : Disabled Engine Diagnostics General Catalyst Test Enabled : Disabled Post O2 Test Enabled : Disabled System General Clutch Interlock Enabled : Disabled Speedometer Speed Limiter Speed Limiter 155 : 255 mph Speed Limiter 2 155 : 255 mph Speed Limit 2 stoveguyy 02-23-09, 10:57 PM its funny what shows up at wrecking yards around michigan. or automotive recyclers. seems these low mileage cars get scrapped and somehow the drivetrains get reused. you could drop in a blown smallblock like a thousand other rodders have done or put in a late model setup. very cool. AJxtcman 02-24-09, 09:18 PM Good news the car runs. PSRmark 02-25-09, 08:31 PM By chance are you working with Joe Ellis from classic wire on this? I ask because he had been calling me non stop to figure out his VATS problem AJxtcman 02-25-09, 11:55 PM By chance are you working with Joe Ellis from classic wire on this? I ask because he had been calling me non stop to figure out his VATS problem The shop I did my work for is located down I85 from my new house in Rock Hill SC. The guy with the Turbo Northstar in the back of the Mazda truck got us hooked up. The shop has built some very impressive show cars. AJxtcman 04-13-09, 10:48 PM Check out the Photo's. 3 pages so far. click below http://www.hotrodconstruction.com/gallery/albums/album03/Picture_2979.highlight.jpg (http://www.hotrodconstruction.com/gallery/album03) AJxtcman 04-13-09, 10:52 PM WOW http://www.hotrodconstruction.com/gallery/albums/album03/Picture_3095.sized.jpg brewhog55 07-05-09, 09:19 PM AJ, Here is a link to my post from 6 mos ago, http://www.cadillacforums.com/forums/northstar-performance-technical-discussion/155284-2007-xlr-4-6-hot-rod.html We have put this aside for the last couple of months and are now trying to get this going again. I would like to know more about what you have done to get the motor running? Any help you can offer would be great! These are great motors and our next project is to put a supercharged one in a 57 Cadillac Eldorado Brougham. Don brewhog55 07-06-09, 12:40 AM AJ P.S. I guess I am too new to this forum because it won't let me send you a PM. Don | |
