: "Y" code vs. "9" Code
Roswell256
07-02-04, 09:10 AM
I Was under the impression that the Y code was the better engine but from reading one of the messages here it was explained as the Y code is 295 and the 9 code is 270.
Which is correct? And just when I'm starting to think I have the better one.
Also what chances are there to put a 295hp engine in where a 270hp engine was? too much work for the performance difference?
JSMeloche
07-02-04, 10:21 AM
Code 9 is the STS 295 hp
Code Y SLS 275 hp
The main difference between the 2 engines is the cams. And you have more torque at lower rpm on the SLS. The differential ratio is also different but i dont remember the exaxt number.
slk230mb
07-02-04, 11:25 AM
I think its 3.73 for the 9 and 3.11 for the Y.
STS
07-02-04, 02:00 PM
9=good.
Ranger
07-02-04, 05:30 PM
You don't want to swap engines. You'll have the wrong final drive. Even if you swap tranny's as well, you'll still have the wrong PCM. Way to much work and $$$ for a few ponies.
Which is better? Personal preference. The "Y" will give you more low end torque and better gas milage. The "9" will give you more HP...... at 6000 RPM. How often are you at 6000 RPM?
94CaddyConcours
07-16-04, 07:59 PM
Roswell256 I'm also a owner of a 94 Caddy Concours:)
94CaddyConcours
07-23-04, 05:07 PM
i :) F I CHANGE MY ENGINE FROM Y TO 9 WHAT OTHER PART DO I ALSO HAVE TO CHANGE
