: Coolant,Oil problem
CaddyMD
02-03-09, 07:14 PM
I've been getting problems with my coolant by the top of the tank has a residue of a gel like substance. We ended up flushing out the whole system and placing fresh Dex-cool back in. The problem is alot better than before but there always a little bit of left that comes back every couple of weeks. Then i noticed that i was low in oil. So i unscrew the cap to put the oil in. What i see is a orange like pudding substance lining the tube. But the dipstick is fine and has none of this substance. If this stuff in my engine now but why isnt it on the dipstick? Any help guys?
lakesidepark
02-04-09, 01:39 PM
it floats to the top?
CaddyMD
02-04-09, 08:37 PM
What are you asking if you asking if the dipstick was full. Then no it was at 1.0l mark.
Vesicant
02-04-09, 09:08 PM
Could be the symptoms of an oil cooler going bad. Generally starts with what you've described so far. Coolant gets in the oil and oil gets in the coolant giving you the sludge.
AHazzardToAll
02-05-09, 12:00 AM
yep :alchi: they're always fun.
CaddyMD
02-05-09, 01:36 AM
Is this expensive to fix? Any recomendations I asked a mechanic a he said i could have a head gasket leak? Or does the oil cooler make more sense?
CaddyMD
02-05-09, 01:59 AM
If I would end up buying the part does anybody have step by step instructions on how to replace the oil cooler. Or is their anyway of actually fixing the current one?
sassanach
02-05-09, 05:41 AM
ave a shufti here.
http://www.omegaowners.com/forum/YaBB.pl?num=1221081908
CaddyMD
02-06-09, 01:50 PM
ave a shufti here.
Would you happen to know of a site to find the cheapest one I really don't wanna put that much more money into the car? thanks man
sassanach
02-06-09, 04:12 PM
not really,over here a complete oil cooler kit from vauxhall/opel is about 100 or approx $140.00-150.00.
CaddyMD
02-06-09, 06:15 PM
Thanks man I plan on doing this by march cause right now its just too cold.
hvy
02-07-09, 09:19 PM
When my oil cooler went bad on my 98Cat I had oil in the coolant there was never coolant in the oil if you have both I would check head gaskets before I bought a new oil cooler
gixxer_751
02-23-09, 08:26 PM
here's what mine dide..
white/milky sludge down oil filler tube
loosing coolant after a couple rides
smoking (white) from driver side and leaking coolant toward back of engine drivers side (at times)
solution:
buy "complete" oil cooler off ebay @ $355 (shipping included)
pay someone to put it on for you
CaddyMD
03-12-09, 06:22 PM
solution:
Actually I just checked both problems areas that I was having and its actually looking better somehow. I mean every time I check it i clean both areas and wipe everything down. It looks like it not as severe as before. I still wanna replace the thing soon.
The problems that I was having with mine is above on my first post but as far as I can tell Im not really losing any coolant at all I cant tell a difference.But I never had white smoke come out of anywhere. The one thing I have noticed is it seems because of this problem my mpg in the car has gone down. Does anybody know of any good deals for the oil cooler(engine one) because it their multiple one for like transmission and something else any help guys?
