View Full Version : 98 Catera Thermostat Change
Positive P
02-02-09, 08:09 PM
I have a '98 Catera that needs the thermostat changed.
I have done a search on this but there is mostly only discussion.
I've never tore into one of these engines and I'm looking primarily for at least a few pics, if I screw something up, I don't know what I'll do.
I was told you have to remove the intake to change it, but I can't even see it.
Anyone know where to find pics of a similar job?
AHazzardToAll
02-02-09, 09:02 PM
http://www.omegaowners.com/forum/YaBB.pl?num=1229464812
Looks like a fairly complicated procedure. You need to change your valve/cam cover gaskets or your oil cooler while ur at it?
AHazzardToAll
02-02-09, 09:03 PM
mostly just prep work. It's not bad really. I did the cam covers on mine and it wasn't bad.
Warez
02-03-09, 01:20 AM
I just chnaged mine and it was a huge PITA!
A few tips:
Be careful when you pull out the aluminum pipe that fits into the T-stat. On the end where the rad hose attaches; there is a tab with a torx bolt that holds it in place. Removing that bolt is tough because of the limited space. A small mirror will be very helpful, especially when putting the bolt back in.
Once the bolt is removed, DO NOT pry or pull on the tab to remove the pipe. It will break off and you will need a new pipe, its $80. The guy at the GM parts counter warned me of this when I bought the t-stat. He said most people end up coming back to buy a new pipe.
Also GM now uses a new redesigned t-stat with a much thicker mounting face. This means that the 2 stock bolts that hold the t-stat in will not be long enough for the new t-stat unless your dealer still has the old style t-stat in stock (unlikely). So go pick up 2 longer bolts form a hardware store (cheaper than the dealer).
You will also need 2 new O-rings for the pipe. The t-stat has the one that sits on the block.
gixxer_751
02-23-09, 07:29 PM
OUCH....you've got to be shitting me!!! all to change the thermostat..fugg
