: Green gooooooo !!!!
01-25-09, 12:22 PM
Well all is well so far had a air shock leak, now replaced shocks all good now.
But the last couple cold days I start the car to let her warm up and then under the front right corner engine bay on the ground there is a little puddle of neon green gooo,
it is not Engine anti freeze realy runny and sweet tasting.
This is more like oily green slim is the airconditoner oil??? or what do I have here?
01-26-09, 11:18 AM
on the ground there is a little puddle of neon green gooo....realy runny and sweet tasting.
Sounds like anti-freeze to me...maybe a weak mix that is freezing?? Or maybe a mix of Dex-cool and regular antifreeze leaking out? Sure you are not losing any coolant?
01-26-09, 11:19 AM
guess it could be AC oil with ultraviolet dye leaking and if your AC is fubar with a leak on the condensor right side then maybe..
01-26-09, 08:46 PM
Its not anti freeze I ahve the long life and that is orange
01-30-09, 05:59 PM
Probably the ac oil dye. That stuff is neon green in color.
