: question about gold keys
01-09-09, 09:36 AM
does anyone know which keys i need? I only have the ignition key and it has the E stamped on it. I do not have the door key and was wondering which key i need to order so it will be the right one. Ive seen B,D,and H. I have a 91 brougham. thanks guys for your input!
01-09-09, 11:32 PM
I have an 89 Brougham d'Elegance, and the ignition key is stamped "C", and the door key is stamped "D". Somebody may have changed the ignition switch to the E keyway, but I'm sure the door and trunk locks are original.
To be sure (and since you don't have a key to duplicate), you should go to a locksmith and see if they can tell which keyway you have, and make a key for it. If they can't help you, go to a GM dealership and see if they can order you a set of keys, using the VIN. The dealership will probably only be able to get silver GM generic keys, but once you have duplicates of the original keys, then you can get them in gold.
01-10-09, 05:24 PM
Its E and H.
01-13-09, 10:48 AM
thanks a bunch!
01-16-09, 03:20 PM
wow, i found a great website to order keys from. http://www.mysecuritypro.com
