View Full Version : Heated Seat Failure Diag.
Yaemish
01-04-09, 12:57 PM
I've done the whole heated seat element fix before; but I don't remember how to determine element failure (I know that its usually the element). In my 02 Seville, the passenger heated seat button will switch on to both high and low. However, there is be no heat and I will hear a clicking sound every 30 seconds or so (it is the same sound you hear when you first press the button).
I don't remember hearing the clicking when the other seat failed, so I was thinking that it could possibly be a module under the seat... I just wanted to double check.
SwampeastMike
01-04-09, 01:56 PM
Disconnect connectors C-2 (4 pin) and C-3 (2 pin) from the heated seat module.
Check resistance between the two pins of connector C-3. Should be 1.5 - 10 ohms. If not, seatback heater is bad.
Check resistance between pins A & B of connector C-2 (all four wires are black--Pins A & B are both across from the rounded end tab). if resistance not between 1.5 - 10 ohms, the cushion heater is bad. The other two wires in connector C-2 are for the temp sensing element. Resistance should be between 850-1150 ohms at moderate temperature. If not the sensing element is bad.
Yaemish
01-10-09, 04:28 PM
Its the element. I am trying to find a site to order the part from (I found that it used to be 25755075 at GMpartsdirect) but I can't find it. Anyone know where to get the new element?
Yaemish
01-10-09, 04:30 PM
Where can I buy the element? GMpartsdirect doesn't list it anymore.
Ranger
01-10-09, 06:13 PM
Have you tried gmotors?
xPosTech
01-10-09, 06:37 PM
There are lots of threads on repairing the elements, replacing the elements, parts, etc. Search for "repair heated seats".
I think I would try repairing first. But that's just me.
Ted
mrpib
01-18-09, 11:34 PM
This is good information, but where is the "heated seam module" from which I am supposed to "disconnect connectors . . .":cookoo:
chubbyranger
01-18-09, 11:39 PM
Under the seat? :rolleyes:
mrpib
01-21-09, 12:07 AM
Is the heated seat module the same as the relay? I have not been able to locate the relay, but the behavior of my seat points to a bad relay.
Ranger
01-21-09, 12:08 AM
No, they are different.
mrpib
01-21-09, 12:26 AM
I assumed they were different. Thanks for the confirmation. I still have the one question remaining.
Where is the heated seat relay on a 98 Deville?:confused:
Ranger
01-21-09, 12:33 AM
If it has heated seats, I think it is under the seat.
