: Timing chain routing??
12-31-08, 01:03 AM
Getting ready to set timing and put the motor back in my car (:highfive:) but I need a diagram for the timing chain setup..
Anyone have one?.. 1999 Cadillac DeVille Base, VIN Y.
Thanks in advanced....
12-31-08, 06:24 AM
Hey Chacen check this out- AJ has a great reference for this on the Fiero Forums:
12-31-08, 01:42 PM
01-01-09, 11:42 PM
Thank you both that was exactly what I needed!
01-02-09, 12:03 AM
No problem!:thumbsup:
04-02-14, 02:50 PM
Hello everyone i have a problem I'm working on a 02 STS with north star engine , i took my heads to a machine shop and they took off the cam sprockets i dont remember how the went on, can anyone tell me how to set the sprockets so when i set the timing chain its correct
04-02-14, 03:04 PM
In the future, feel free to start your own thread, instead of tacking it onto a 5+ year old, semi related one.
Can't they only go on one way? IIRC, each sprocket has 2 holes/slots for the pin in the cam to go through. 2 sprockets say RI and RE, and the other 2 say LE and LI.
L = left
R = right
I = intake
E = exhaust.
You put the pin through either the I or E hole depending on which can you're installing it on.
04-02-14, 08:52 PM
I'm confused. Why post the question in the first place in a thread that already has the answer? :hmm:
04-02-14, 10:08 PM
joser, You might want to look at Post #3. There are three (3) timing chains and it takes cam locks to get everything in alignment with Cylinder 1 at TDC so you can install the sprockets, retract the 3 tensioners, set the chains, and unlock the tensioners. Did you replace the tensioner shoes and the chain guide slippers ? Oil everything.
or, http://lmgtfy.com/?q=cadillac+forums+2002+seville+timing+chain+repla cement&l=1
