: Catera 97 all the back lights dont work
12-31-08, 01:49 AM
None of the lights of my catera 97 work. I took it to the Walmart to change the bulbs but they told me that these are not the bulbs issue. Can someone please tell me what to check.
12-31-08, 02:08 AM
sounds like there's a wiring issue, start checking all your fuses first
01-15-09, 02:48 AM
Had the same problem.... The switch located behind the brake peddle is most likely sticking or is just altogether bad. I had to replace mine, I don't remember the exact cost, but I remember it wasn't too much $20-50. It's kind of difficult to position yourself in a way to remove to switch, you need to be somewhat of a contortionist. Also an easy way to keep the brake peddle depressed to get to it is to place a bar in front of the seat and push the brake with the seat positioner.
01-15-09, 09:00 PM
