: Spark Control Module
Josephchevy5596
12-27-08, 09:02 PM
Hey i gotta 94 fleetwood and i need to know where the Spark Contorl Module is located. Can somebody help ASAP please!!!!! Thanks
sven914
01-02-09, 12:52 AM
This may be completely irrelevantly, but the only thing I could find online related to an 87 Blazer with a .350. Apparently the the .350 used in the 87 Blazer is the same engine used in the Fleetwood's of 93/94. The Ignition Module (I think it's the same thing as a Spark Module) on an 87 Blazer is located in the distributor, under the rotor. There is one problem I ran into, the online encyclopedia contradicts it's self. One page said that the .350 was offered in 94 and another said it only available until 93, and that the Corvette LT1 Engine took its place. Without knowing your exact engine, this is the best I can do.
jey
01-02-09, 01:27 PM
The correct information is that the 94 Fleetwood has the LT1, the 93 has the L05, both are 350 cu in of course.
sven914
01-04-09, 11:14 PM
That what I thought, and I was unable to find anything about the ignition control module on an LT1.
N0DIH
01-08-09, 01:58 AM
It is on the driver's side head, front above the AIR pump. Look for HV wire to coil, it is under it.
Mod tip: Remove and add a nut between the head and the module and if you need, add longer bolts, keeps it considerably cooler. Mine was enough to touch after driving, but before, no way.
