View Full Version : Changing Fog Lamps
coralreef35mm
12-26-08, 01:57 PM
Is it hard to change the fog lamps out? Both lenses are cracked...I see I can get a set for about $100 on Ebay.
sam hamm
12-28-08, 01:48 AM
nahh its not really hard at all. but before you buy those look into 99-02 gmc sierrra. i think they are the exact same.
bbang
02-16-14, 02:19 PM
how do you change out complete fog light assembly on 2005 escalade? passenger side took rock
z0lt3c
02-16-14, 02:50 PM
This a pretty old thread... each fog light housing is secured via bracket the the bumper with 3 screws. The screws are located on top of the fog light assemblies, you will need a small box wrench, and small hands, and patience, to get the screws out, but it's a fairly straight forward job. I used TYC housings from Amazon and I upgraded them to HID while I was at it. If you don't replace both at the same time, be prepared for a cosmetic difference between the two housings, bothers some people....
bbang
02-17-14, 01:42 PM
Thank you for the reply z0lt3c
zeeter21
02-17-14, 02:02 PM
I just did mine on 2005 esv and its simple just not alot room for hand and ratchet but you will get it very simple
the cadillac man
02-17-14, 02:47 PM
I used a long extension when I replaced mine as there isn't much hand room it made it a lot easier to work
smelly$cat
02-18-14, 03:54 PM
My lens fell off the other day. I got a new one off ebay for ~25.00 shipped. 30 min project to swap it out.
dahubby98
02-19-14, 10:30 PM
Mine fell off and I got some clear winshield sealant and just replaced the lens. 10 bucks
the cadillac man
02-19-14, 11:35 PM
Had the lens not looked like crap I would have done this on the one fog light that had the lens fall off in the driveway on my moms 02(still have the housing and lens so I may try that)
jacob9582
02-20-14, 06:57 PM
Amazon.com. Stock fog lamps are $30 bucks. About 15-30 min a side to install depending on how rusty your bolts are.
the cadillac man
02-20-14, 10:22 PM
That's where I got replacements for both trucks
I done it in 30 mins for both sides on mine with the install of hids
It was 15 total for my moms 02(yep I work quick)
