View Full Version : stumble, stall and walk
12-26-08, 02:44 AM
I have pulled the trouble codes from the digital cluster of my 94 Fleetwood it has a bad hesitation and stumble after warm up. you can drive it then all of a sudden it will act as if it had bad gasoline.shut the car down and 5-20 min later it runs fine again.
16 Distributor low resolution pulse not received by ECM
would this be a bad distributor?oil intrusion? both? something else as well?
Thanks for all your help
01-02-09, 01:05 AM
Are you sure you read it correctly because DTC 16 is Generator Voltage Low in OBD-1. Also you ignore any code (it should be 12) saying that the Distributor reference single is not being received by the ECM, unless the engine is running.
