: Dex Cool
stepfon
12-08-08, 01:01 PM
have anyone ever put dex cool in a car that uses antifreeze? . . .i got a 95 astro and am thinking of adding dex cool in it
nickc50310
12-08-08, 01:14 PM
That sounds like a bad idea.
Coma
12-08-08, 01:23 PM
Honestly, when I make a zon, I put about 50 into vitality and then pump dex the rest of the time. You literally end up needing it in the later levels when you just can't dish out enough damage. Especially if you have a low %ed bow from a bad imbue.
nickc50310
12-08-08, 01:57 PM
honestly, when i make a zon, i put about 50 into vitality and then pump dex the rest of the time. You literally end up needing it in the later levels when you just can't dish out enough damage. Especially if you have a low %ed bow from a bad imbue.
what!?
Submariner409
12-08-08, 02:01 PM
Basically he's saying that if the car came with green stuff, don't try to fix it better.
Use a name brand low-silicon green (ethylene glycol) coolant mixed 50/50 with distilled water (supermarket, $.89/gal.).
LS1Mike
12-08-08, 03:19 PM
No dex and green, that is bad. Just use the Green stuff.
Ranger
12-08-08, 07:19 PM
Dex IS antifreeze. Why do you want to change it?
