prs1989
12-01-08, 08:52 PM
Hi, I just wanted your guy's opinion on this: '78 Fleetwood, 425 of course!
This is especially noticeable at night because the lights are on, but when I start the car everything is bright, the outside and inside lights and the heater is blowing strong, etc. Then, as soon as I drop it into reverse or drive, everything dims quite a bit, I mean it IS noticeable. You can even hear the heater blower motor slow down. When I give the car gas, everything brightens up right away and acts like normal, its just when I am idling in gear and come to a stop. If I use one of the power windows or the locks, it happens even more. Now I know its only a 63 amp, and all older cars "dim" a little when you use the accessories, but I think this is excessive. Now that it is really cold, I have the wipers on, the lights and the rear defogger on. The rear defog really seems to use A LOT of power, when that is on the problem happens even when driving up to 40 MPH, if that makes sense. Basically, if there are only one it two accessories on, the dimming only happens at idle. If there are more accessories on, it happens at idle AND while driving, as soon as I take my foot off the gas to coast, everything dims down until I give it gas to accelerate again, like to pass another car for example. My '79 Fleetwood never did this. GEN light does not come on, yet, and has a brand new battery. No noises coming from that area of engine. I took it to the local place and had them test the alt. and they said it was OK!! However, it was in PARK when the test was being done. What do you think? Belt too tight/loose? Idle set wrong? Alternator just shot?
Thanks
Thanks
