Ink it
06-24-04, 06:18 PM
how do u set the clock (92 allante)seams like it would be easy but can't find it in the manuel.. Thanks tattoo matt:cool:
| View Full Version : setting clock Ink it 06-24-04, 06:18 PM how do u set the clock (92 allante)seams like it would be easy but can't find it in the manuel.. Thanks tattoo matt:cool: magicmuffler 06-25-04, 09:51 PM on my 89 allante you press the reset button & hold aprox 5 seconds you will then see 2 arrows 1 up 1 down.the first number will be flashing you then press the up or down button button & the numbers change. When its correct press reset then it moves to the next number do it again when time & date are correct you then press any other button to get out of that mode hope this helps. the Mufflerman | |
