View Full Version : Chassis Components That Need Lubing For An 06 Escalade?
TAWoody
11-26-08, 05:15 PM
I've searched all over the darn place but can't find any specific info on Escalades. The manual says to:
Lubricate the front suspension, ball joints, steering
linkage, transmission shift linkage, and parking
brake cable guides.
Now I've seen the below guide but that's not for the 06 model Escalade. I also don't believe that guide shows where or how to lube the steering linkage, transmission linkage, and parking brake cable guides.
http://www.gm-trucks.com/home/Technical/Ma...-Replacing.html
Can anyone elaborate further on these lube points?
Thanks
TAWoody
03-11-09, 10:34 PM
bump. Still need to lube these bad boys.
obxdiver
03-12-09, 05:54 AM
There are 11 zerks. Here are their locations.
Grease Zerk Fitting Locations (11)
Driver's side upper ball joint
Driver's side outer tie rod end
Driver's side lower ball joint
Driver's side inner tie rod end
Driver's side pitman arm
Passenger's side idler arm
Passenger's side upper end of idler arm mount
Passenger's side inner tie rod end
Passenger's side lower ball joint
Passenger's side outer tie rod end
Passenger's side upper ball joint
luxurylife33
03-12-09, 10:06 AM
nicccce. Any reccomendations on grease to use??
obxdiver
03-12-09, 07:04 PM
Most any all purpose grease should work, but its a Caddy. Use Mobil 1 Synthetic. She will love u for it
http://www.mobiloil.com/USA-English/MotorOil/Other_Products/Mobil_1_Synthetic_Grease.aspx
luxurylife33
03-12-09, 07:58 PM
cool, hopefully walmart should have it for cheap.... they always have my synthetic oil for dirrrt cheap
KrazyKeith
03-13-09, 02:38 AM
Dropping my lade off for an all wheel alignment tomorrow, going to ask them to grease all the zerk locations, hopefully all my suspension stuff is good to go as well. She been pullin to the left on the highway a touch.
