: I need help
Moezy
11-15-08, 11:16 PM
changed the camshaft sensor and still have p041 code on cadillac 94 sts
chubbyranger
11-16-08, 06:44 AM
Did you change both sensors? I think there are 2 but not positive for your year. Usually posted as an upper and lower sensor. Search CKP here. You'll get a lot to wade through but your answer should be here.
Submariner409
11-16-08, 09:06 AM
P041....CaMshaft Position sensor (CMP) signal fault. The single sensor in the drive belt end of the rear cam cover ? Held in by a 10mm bolt, and murder to get to ?
If that's it, you're in the wiring harness tracing business. Might be a dirty connector.....any oil leak in the cam cover gasket goes right to that corner.
The CranKshaft Position sensors (CKP) (2 - A & B) are down on the side of the block next to the oil filter adapter.
OBD-II uses P0340 and P0341 for the CMP codes.
Did you clear the codes, and if so, is the P041 Current or History ?
