badboris
11-10-08, 07:51 PM
when i installed the belt tensioner, i stripped the thread in the block of N* :banghead:
what is the best or easiest way to fix
| View Full Version : strip thread in block badboris 11-10-08, 07:51 PM when i installed the belt tensioner, i stripped the thread in the block of N* :banghead: what is the best or easiest way to fix Ranger 11-10-08, 09:58 PM I would think you could use a Helicoil on something like that. submariner409 11-11-08, 10:39 AM A Helicoil would be OK there, but you'll need to go at it from inside the fenderwell. Move anything necessary in the engine comartment, put the front end on jackstands, and remove the wheel/tire and fenderwell liner. I believe your engine uses metric threads, so check first........ | |
