View Full Version : Trouble codes
unruley247
06-22-04, 12:36 PM
Hi i own a 96 deville and i have the following codes need help!!!!!!
P 1350 and P1370
vlb90
06-23-04, 08:33 PM
here is a good link to look up those codes
http://www.diagnosticdialog.com/LookupCode.asp
unruley247
06-24-04, 01:18 PM
What does the following info mean?P1370Vehicle Qualification:Cadillac DevilleDescription:Ignition Control Module 4X Reference Circuit Too Many PulsesP1350Vehicle Qualification:Cadillac DevilleDescription:Ignition Control (Ignition Control) System FaultDo I need to change my ICM?
Logandiagnostic
06-24-04, 03:23 PM
P1350
Under normal system operation when the key is turned ON and until engine RPM is high enough for the PCM to control spark, the PCM will open the bypass circuit (CKT 424) to the Ignition Control Module, the IC module will then ground the Ignition Control circuit (CKT 423). This is called module mode because the IC module is controlling spark. Once the engine speed is high enough (about 65 RPM), 4X reference pulses are received and no PCM faults are detected the PCM will close the bypass line and in response the IC module will unground the IC circuit, this allows PCM control of spark. This is called the ignition control mode. This diagnostic test is used to check for faults in both the bypass circuit and the IC circuit. To check both circuits this diagnostic runs two tests, one during crank and one while running. If Ignition Control pulses are detected by the PCM on the IC line while in module mode (cranking) or if no Ignition Control pulses are detected by the PCM while in ignition control mode (running) DTC P1350 will set.
Conditions for Setting the DTC
Test Conditions
Cranking Test
DTC P1376 not set.
At least 1 4X reference pulse has been received by the PCM.
Running Test
DTC P0322 and P1376 not set.
Failure Conditions
Cranking Test Ignition Control pulses are received by the PCM when cranking or running test has failed THIS ignition cycle.
Running Test No Ignition Control pulses are received by the PCM while engine is running.
Action Taken When the DTC Sets
PCM ignition control is disabled for ignition cycle.
PCM disables EGR.
Transaxle shift adapts are maintained at current levels.
The PCM will illuminate the malfunction indicator lamp (MIL) when the diagnostic runs and fails.
The PCM will record operating conditions at the time the diagnostic fails. This information will be stored in the Freeze Frame and Failure Records.
Conditions for Clearing the MIL/DTC
The PCM will turn the MIL OFF after three consecutive drive trips that the diagnostic runs and does not fail.
A Last Test Failed (current) DTC will clear when the diagnostic runs and does not fail.
A History DTC will clear after forty consecutive warm-up cycles with no failures of any emission related diagnostic test.
Use a scan tool to clear DTCs.
Interrupting PCM battery voltage may or may not clear DTCs. This practice is not recommended. Refer to Clearing Diagnostic Trouble Codes in PCM Description and Operation.
Diagnostic Aids
If fault is not present check terminal contact at the IC module and PCM connectors.
Test Description
When checking for shorts to ground, resistance of more than 10K ohms is usually acceptable although most readings should be infinite (OL).
When checking for circuit continuity (opens) resistance should be 5 ohms or less.
When checking for shorts to voltage take measurements with the ignition ON and OFF.
Disconnect the circuit from all components before performing any circuit check.
Always check or zero the meter before performing resistance checks.
A diagnostic jumper can be created with the terminals supplied in the J 38125-A Terminal Repair Kit. Assemble the jumpers and terminals and cover the exposed terminals with heat shrink tubing. Do not cover the spade of the male terminals.
If the vehicle stalls during this step turn the ignition OFF and wait 30 seconds then restart the engine before attempting to measure the circuit voltage.
P1370
This diagnostic test checks for too many 4X reference pulses between cam pulses. The PCM checks to see if there are 48 24X reference pulses between cam pulses, and if there are, the PCM assumes it is receiving valid cam pulses. Therefore, if the PCM sees more than eight 4X reference pulses between cam pulses, it sets DTC P1370, because the 4X reference signal must be faulty.
Test Conditions
DTC P1376 not set.
Engine speed higher than 496 RPM.
At least 7 CAM pulses received since key ON.
At least one CAM pulse received in the last 0.25 second.
48 24X reference pulses received between CAM pulses.
Failure Condition
The PCM has received more than 8 4X reference pulses between cam pulses.
Test Description
Number(s) below refer to the step number(s) on the Diagnostic Table.
Checking for possible cause of noise (extra 4X pulses) on the Fuel Control (4X) circuit
Logan
www.airbagcrash.com
www.logandiagnostic.com
unruley247
07-19-04, 01:14 PM
Basiclly i need to clean all my conectors!
