View Full Version : Need trouble codes for '83 HT-4100 Eldo
baldizzone
06-22-04, 11:00 AM
Hello,
Thanks for the help in resetting the codes after an alternator change. Would love to know however, what codes 13, 44 and 52 mean. 1983 Eldorado with HT-4100. Thanks.
tacoma
06-22-04, 02:47 PM
13 = o2 sensor not ready
44= lean exaust signal
52=ecm reset indicator
http://eldorado.xlr8d.com/ecm%20codes.jpg
:coolgleam :coolgleam :coolgleam
bigred
06-22-04, 02:56 PM
Make sure your O2 sensor is connected properly. If it is, you probably need a new one. This should correct codes 13 & 44. If you still get a code 13 with the new sensor, there is likely a wiring problem in the O2 sensor circuit.
The 52 just means the battery was disconnected since the last code reset.
peteski
06-22-04, 10:43 PM
I'm not sure why this is not mentioned here in Cadillacforums (or made into a sticky thread)...
There are several places on the web to get codes.
One is:
http://www.ht4100.com/Diags/default.htm
Look under the "codes" link.
And get the Original Factory Service Manual if you are serious about working on your car - it is a must !
Peteski
