AlanK
11-08-08, 03:21 PM
Hi Folks,
I have recently taken on my dad's 94 Eldorado. It is a wonderful car and a joy to drive. However, it has a problem that I can't seem to fix. I've been searching the forums and seen lot's of different suggestions - I'm hoping someone can give me some direction on what I've missed.
1994 Eldorado Touring Coupe 4.6L N*
P032 Current
P071 History
P095 History
The car starts and drives normally while warming up. The problem occurs when I stop somewhere for a few minutes. When I come back out and drive off, the engine will die. Sometimes the PCM is able to rev the engine up to ~1500 rpm and keep it from dying (up down up down etc.), other times it will rev up momentarily before dying, but most of the time it just quits as if I turned off the key. Once this happens it is very difficult to get the car to start, even harder to keep it running for more than a second. The motor can then sit for 30 minutes and then will run normally again. These problems also manifest after about 20 minutes of highway driving, though it is not as prone to dying because of the higher engine revs, it will just jerk and sputter for a while.
Map sensor has been replaced along with fuel pump, FPR, plugs, plug wires (non-oem), coils, ICM, fuel filter & TPS. EGR has been cleaned. I'm out of ideas (and money) so if anyone has a suggestion I would really appreciate the help.
P032 Current
P071 History
P095 History
