: URGENT: car keeps running after turned off.
gt723
11-06-08, 11:42 PM
I looked at a 2005 CTS-V today, but the car had two problems. Pleas help me determine how to adjust my offer.
1. The car runs for about two or three seconds, then shakes and shuts down after turning the ignition off. Is this normal for a high compression engine or is it a problem?
2. Error code P0708 - is this a CAGS problem? It never made me skip-shift when I was test driving it.
Would this be enough to scare you from buying the car at a good price?
Thanks a lot.
heavymetals
11-06-08, 11:44 PM
Motor mounts and bad gas.
Mystical_Ice
11-07-08, 12:21 AM
well motor mounts would account for the shaking... my car does that, but it doesn't run for 2 or 3 seconds on its own.
yes, it takes 2 or 3 seconds to stop TURNING, but when i take the key out, it starts shaking (dying) right away.
heavymetals
11-07-08, 12:33 AM
Dieseling is usually the result of: bad gas, really bad plugs, or leaking injectors.
allen sumwalt
11-21-11, 10:44 AM
i have a 2005 sts and i was driving the car and got to were i need to and shut the car off and the engine still was running everything else was shut off but the engine os i pulled the relay to the fuel pump to shut the engien down and i unhooked the battery ,has any one else had this problem oh the other thing is the start button has alot of wear on it and for a car that does not have lot of miles on it i thought maybe it . not sure though iam looking for a place to buy taillight assembly anyone know were to buy a used one for the driver side or a new one !
CancerJCC
11-21-11, 07:36 PM
82969
