: 2004 Escalade Airbag Light On
11-03-08, 10:21 PM
Please help with my airbag issue.
- DTC B0092 Set.
- Both the rear view mirror indicators are on (Both the ON & OFF indicators for the passenger airbag are lit).
Dealer said the passenger presence system is bad - so I replaced the module under the seat and also the bladder under the cushion. Same problem after replacing those two parts.
I tested the bladder weight sensor separately by applying 5V and measured the voltage at the vout pin - appears to be working cause when I press on the bladder cells the vout goes down.
Then I checked the connector that connects to the bladder weight sensor for the 5V and I get 0v - something is not right here. The 5V, GND, Vout wires appear to connect to the square sensor module under the seat - but I already replaced that sensor as well.
Does anyone have a wiring diagram for the airbag system?
Any help will be appreciated.
