gdorell
11-02-08, 05:58 PM
i noticed the motor i have has oil lines thats looks like went to a cooler. did these cars have a seperate oil cooler from the factory?
| View Full Version : 1990 350 oil cooler question gdorell 11-02-08, 05:58 PM i noticed the motor i have has oil lines thats looks like went to a cooler. did these cars have a seperate oil cooler from the factory? jayoldschool 11-02-08, 08:03 PM If it is the same as the B cars with the oil cooler option, then there will be two lines going into each radiator tank. One side is engine oil, one side is transmission fluid. gdorell 11-03-08, 10:03 AM thats what i figured the case was. didnt know they used that radiator for engine oil as well. N0DIH 11-03-08, 11:56 AM Cadillac often made the radiator oil cooler an std. You CAN break out the oil lines to an external cooler if you want, it is a very good system, keeps the oil at perfect temp as long as cooling system is working properly and stock thermostat is used. HD, Towing, Racing I would recommend the SEO 9C1 oil to air cooler. But the lines can be tougher to fit if you want factory fit as the oil cooler in the radiator is a little larger than the std non oil cooler radiator. gdorell 11-03-08, 12:17 PM hmmm...something to think about. i wont need anything extra, this will never be beaten or driving too much N0DIH 11-03-08, 07:17 PM Stock one is very good, just watch for leaks over time, but nothing NEEDS to be upgraded. It allowed a thinner oil to live longer in the cars like 5W30 vs the more robust 10W30 and keep the longer oil life with the ever decreasing ZDDP in the oils. | |
