View Full Version : Where is the radiator drain plug? Lebowski 11-01-08, 03:27 PM I removed the big plastic piece under the front of my '99 STS and I can't find the radiator drain plug. I have a factory shop manual and there's a picture but it's not very helpful. Is it on the driver's side or passenger's side and is it towards the engine or towards the front of the car? There's a big piece of metal under it that doesn't appear to be removeable which makes the radiator very difficult to get to. These late model Cadillacs sure weren't designed to be worked on by the average joe....:( creeker 11-01-08, 04:31 PM I removed the big plastic piece under the front of my '99 STS and I can't find the radiator drain plug. I have a factory shop manual and there's a picture but it's not very helpful. Is it on the driver's side or passenger's side and is it towards the engine or towards the front of the car? There's a big piece of metal under it that doesn't appear to be removeable which makes the radiator very difficult to get to. These late model Cadillacs sure weren't designed to be worked on by the average joe....:(
I'm quite sure (if your in drivers seat)that it's the lower left of rad.,on the
engine side,it's on the vertical surface, this has been discussed quite a bit so check "search". It is inset on the rad. Hope this helps. ewill3rd 11-01-08, 04:33 PM Even if you find it, I rarely advise using it.
Why do you want to drain the coolant? I usually just pull a hose off with a catch pan underneath.
The reason being, the older the car gets, the more likely the drain screw is to break on removal.
It should be on the passenger side just above the lower mounting insulator on the vertical portion of the tank if you want to find it. creeker 11-01-08, 04:45 PM Even if you find it, I rarely advise using it.
Ditto, I should have mentioned when I did my 97 sts,I drained the lower rad. hose. Lebowski 11-01-08, 05:03 PM I'm going to put in some K&W Block Seal to try to fix my alleged blown head gasket problem. See my other thread titled "It overheated again" for all the sordid details. Thanks for the info....:yup: Lebowski 11-01-08, 06:07 PM I spent half an hour looking for the damn drain plug and couldn't find it. Also, both radiator hoses appear to be coming out the top of the radiator. Which one is supposed to be the lower one-the one on the driver's side with the thermostat inside or the long one that runs across the front of the car? :bonkers: Even if you find it, I rarely advise using it.
:hmm: Are you sure Bill? My daughter had a '99 and I could have sworn it was on the drivers side. submariner409 11-01-08, 06:19 PM Lower hose is the driver's side. Crossflow radiator with internal baffling, therefore the radiator and block remain 1/2 full when you pull the "lower" hose.
Although it doesn't do US any good, the professional flush machines hook up to the system and literally displace all the existing coolant with fresh product. As DIY'ers we're sort of at a disadvantage........ Driver's side. Crossflow radiator with internal baffling, therefore the radiator and block remain 1/2 full when you pull the "lower" hose.
That's why I prefer to pull the plug. It's the lowest point and you stand to drain a little more than just pulling the hose. That said, breaking the plug would suck. I haven't yet. Lebowski 11-01-08, 06:47 PM So now it's on the driver's side? :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: pimpdaddycaddy91 11-01-08, 06:48 PM On my '99 Eldorado it is on the drivers side bottom corner of the radiator on the engine side. it is extremly hard to find and even harder to access with anything to turn it with. I got mine to drain there but it is almost impossible to access. it would be easier to remove the lower hose.
I hope you have luck with your potion but I doubt it with the problem of the headbolts stretching/striping, not just HG prob but headbolt problem. I am in the process of pulling my engine apart. I have it out but I dont have alot of time to work on it. Hopefully in the next couple of weeks I'll have it done. If it works.... It's not the head bolts that stretch or strip. It's the female threads in the block. Lebowski 11-01-08, 08:14 PM I found the drain plug on the driver's side and have filled and drained the cooling several times as per the instructions on the can of K&W Block Seal. By the way, the guy at the NAPA store where I bought it, who is the store manager, told me he sells a lot of this stuff and has never had any complaints about it. (I know you pessimists don't want to hear that.) Anyway, tomorrow I'll flush it a few more times to remove all the coolant and then put it in and wait 24 hours for it to set. That means that by Monday night the car should be ready for a trip to California and back.... :lildevil: pimpdaddycaddy91 11-01-08, 10:18 PM Ranger,
Well I meant the threads striping not the bolts, its just too difficult to go over the details of this major design flaw that has plagued an otherwise bulletproof engine.
Lebowski,
As for being a pessimist, I may be, and I also know some NAPA guys that actually do know what they are talking about but I certainly trust experieced certified GM technicians, which there are many on this site, more than an auto parts store guy. I do still wish you good luck, from a do it your self guy to another we need all the help we can get. Thats why I love this forum so much. I dont wish any major repairs on you but the fact of the matter is there is more to the northstar headgasket problem then just the headgasket. That fix in a bottle stuff may work well on other cars but it probably wont work as well on a northstar as with other engines. And it is still just a bandaid even if it holds up for awhile the problem is still there, like bubble gum on a dripping pipe.
I know what your up against too. My Eldorado has been sitting in my driveway for over a year while Ive been saving up enough money to have a shop do the job for $3500. Now that I have the money I still dont want to spend that so I dove in the repair myself with much help from this forum. I would not be able to do the job without the help from this forum.
So again I will wish you good luck with many more miles on your Cadillac. There is nothing better. submariner409 11-01-08, 10:42 PM Lebowski, have at it and best of luck. All we ask is a report after your (99 STS) drive to the West Coast and back.
Drive safe. Lebowski 11-01-08, 11:20 PM I said it would be READY for a trip to California and back, not that I was going to actually do it. My wife and I are planning a 700 mile round trip to the Chicago area and back on Thanksgiving day, and after spending 4-5 hours with my 81 year old father and other family members we're going to head home that evening. We had been planning on driving the Caddy but now we'll be going in either my truck or my wife's Honda Insight (kind of small but it gets 58 mpg).
If by some miracle this sealant actually works I'm going to try to sell the car immediately, if not sooner. No more Northstar engines for me....:bonkers: pimpdaddycaddy91 11-02-08, 12:27 AM Well, I certainly hope you disclose the headgasket problem if you sell it. creeker 11-02-08, 04:36 PM On my '99 Eldorado it is on the drivers side bottom corner of the radiator on the engine side. it is extremly hard to find and even harder to access with anything to turn it with. I got mine to drain there but it is almost impossible to access. it would be easier to remove the lower hose.
When I was asking same thing on my 97 sts,I was told I could remove air cleaner housing and would probably be able to see where the drain cock was. Does anyone remember this?. ewill3rd 11-02-08, 04:50 PM Ranger, no I am not sure.
I can't keep track of all of them and I believe it when I am told it was on the driver's side.
Like I said though, I rarely use them. Usually I am only doing a water pump or cover and don't need to get the coolant much lower than that.
Sorry if I caused any confusion, I didn't mean to imply that the right tank was for sure where it was located. No problem Bill. I always trust your word over my memory anyway. You know what they say, "The memory is the second thing to go". Just wanted to be sure. ewill3rd 11-03-08, 08:11 AM My memory was the first thing to go... don't tell me what is next... I want it to be a surprise. On second thought you could probably tell me because I'll probably forget :lol:
If I had done one recently I could have known for sure, but as I said, rarely do I use them anyway.
I have had a few break. You can usually fix it, you just dig the broken part out and try to find a replacement. |
