: Clutch issues
10-30-08, 11:02 AM
So I did a search on this but I didn't really see anything that matched my problem.
My clutch seem fine most of the time, but when it's cold out (below freezing) , when I start the car and puch the clutch in, it barely comes back out. As it warms up it goes away,, but the colder the outside temp. the worse it is.
I think when it gets realy cold, I won't be going anywhere.
Is this the same problem everyone else has?:hmm:
10-30-08, 11:40 AM
Haven't hear of this one. What have you done to fix it? Have you at least tried bleeding it yet?
10-30-08, 11:46 AM
make sure u have enough fluid in the clutch resevoir... pop the hood and have a look
10-30-08, 11:51 AM
It is the car's way of telling you it doesn't want to go out in all the lousy weather you guys are having.
10-30-08, 11:53 AM
Yes, the level is good. I added some two months ago and did just pumped the pedal alot. WEorked fine till last week.
10-30-08, 01:10 PM
I've experienced that in the last two car's I've owned when it's below feezing out. When the car starts to warm up it goes away. You might be able to flush your fluid with some that works better in the :canuck: temperatures.
10-30-08, 08:55 PM
I guess i'll give it a try...
10-30-08, 09:27 PM
The same thing happened on my cts and g35. Just let the car warm up.
