: Best way to go?
ocmdiaz714
10-29-08, 07:26 AM
Don't want to use super glue, what are the best alternatives?
http://i37.tinypic.com/xge1s7.jpg
http://i33.tinypic.com/2a512rq.jpg
http://i34.tinypic.com/2lw9hq9.jpg
jayoldschool
10-29-08, 10:52 AM
1st pic: take out headliner, reinstall.
2nd pic: new signal stalk
3rd pic: couple dabs of silicone caulking, press trim in place, hold with duct tape while the caulk dries
ocmdiaz714
10-29-08, 03:50 PM
Would this be good?
How about getting a new trim panel and signal stalk, where could I find them? And are there any instructions on here on how to reinstall the headliner? Thanks!
http://i2.ebayimg.com/03/i/001/12/6e/09fb_1.JPG
jayoldschool
10-29-08, 08:57 PM
For parts, PM 1990CaddyBrougam. Anthony will hook you up.
To do your headliner:
- remove dome light
- remove hooks
- remove sunvisors
- remove A, B, C pillar trim
- remove rear window trim
- drop the headliner
Are there some screws on that map light assembly so you can take the mount off? Might be easier than doing the whole headliner. I would look for you on my car, but it is boxed in for the winter in the garage...
ocmdiaz714
10-30-08, 01:33 AM
- remove dome light
- remove hooks
- remove sunvisors
I picked this up on my way to work:
http://i38.tinypic.com/54f0qt.png
You think it's any good or should I go with this one that I found on ebay:
http://cgi.ebay.com/General-Purpose-100-Silicone-Sealant-Clear-Caulking_W0QQitemZ280279072994QQihZ018QQcategoryZ6 6914QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
ocmdiaz714
10-30-08, 01:38 AM
- remove dome light
- remove hooks
- remove sunvisors
I'll check for screws yet what should I do once I take it off? It would also be easier to put some silicone on there instead, don't you think? Let me know what's best though, I don't want to half-ass it.
ocmdiaz714
10-30-08, 05:06 AM
I'm also looking for a continental kit if anybody can help me out with that.
dirt_cheap_fleetwood
10-30-08, 01:43 PM
I think they headliner has already been replaced. That is the only way the dome light would have gotten like that. Unscrew the light with the one screw holding it up near the front. Pull it out and forward, then slide the whole light up and back. There is a metal tab in the roof that the metal tab on the back of the dome light locks into. You may have to push up quite a bit to get the tabs to line up right. Replace screw.
