View Full Version : 03 seville pcv location
phil chojnacki
10-25-08, 09:41 PM
anyone know the location of the pcv valve for a 2003 seville 4.6 northstar???
submariner409
10-25-08, 10:23 PM
Remove the plastic engine beauty cover. In the left (front end) of the right (rear) camshaft cover is a plastic line which snakes into the front (accessory belt) end of the engine. There is no PCV valve per se: there is a fixed orifice in the cam cover which is connected to manifold vacuum in the front of the intake manifold. The clean air source is the plastic line which comes from the throttlebody to the (right) end of the front cam cover.
Click on your username and update your profile and personal info with your car, year, model. Makes diagnoses easier.....
Sorry for the parentheses: A sidewinder engine defies accurate parts location if you remember good ol' fore-and-aft configured engines............
AJxtcman
10-26-08, 12:41 PM
You don't have a Valve
They finally went to an orifice after 40 years
phil chojnacki
10-26-08, 04:47 PM
ok thanx
