justindre
10-24-08, 03:24 PM
hi guys how are you, im justin. i have a 2002 sts w 104000 mi. if i were to press on the gas quickly whether driving or parked the motor bogs unless i let off. then ill let off and she'll smell like a old 72 buick's exhaust for a couple of seconds. pulled 2 codes dont remember the #s but it had to do with the map sensor intermittent high. could that affect the motor so drasticly like that...............? thank you guys
submariner409
10-24-08, 04:08 PM
Read up and pull your Diagnostic Trouble Codes again. That's the key to correct diagnosis......but, yes, MAP (Manifold Absolute Pressure) plays a big part in controlling air/fuel ratios: mixture.
Also, a good throttlebody cleaning is probably a good bet, as is a new air filter.
Do some searching for things like throttlebody, MAP, MAF, idle passage cleaning, and similar.
Click on your login name and update your profile and personal info with your car, model, year......makes all this easier when everybody knows what car to diagnose.......
N*Caddy
10-24-08, 07:26 PM
Pray is not the fuel pump…
Codes will tell you everything.
