: Pull strap???
10-23-08, 03:11 PM
I am currently trying to remove my headliner. How do I remove the 3 pull straps that are above each door? The little things you would use to "pull" yourself out of the car. I do not know the exact name for them. Just need help taking them off.
10-23-08, 06:42 PM
Those are called "overhead assist handles" and they have screws underneath the plastic covers on each end. They slide inward to each other to come off. You just need to kind of wiggle them or squeeze them loose. I used a butter knife. Then there's a phillips screw underneath, and it's as easy as that!
Good luck! :thumbsup:
10-24-08, 11:08 AM
I figured that it was easy. Thanks for the help
