View Full Version : Thinking about a K&N cold air intake... BSchorr 10-23-08, 04:43 AM Ive never put one on my cars, Thinking about doing it to my 2000 STS... What are your guy's thoughts on them?
K&N cold air intake
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=370075213371&sspagename=STRK%3AMEWAX%3AIT&viewitem=
or a BOMZ cold air intake...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=170271821538
or a AFM cold air intake...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=150303896204&sspagename=STRK%3AMEWAX%3AIT&viewitem=
My car...
http://i230.photobucket.com/albums/ee137/BSchorr86/2000%20Cadillac%20Seville%20STS/STS_001.jpg
http://i230.photobucket.com/albums/ee137/BSchorr86/2000%20Cadillac%20Seville%20STS/STS_004.jpg
http://i230.photobucket.com/albums/ee137/BSchorr86/2000%20Cadillac%20Seville%20STS/STS_006.jpg msta293412 10-23-08, 09:45 AM Those just suck up hot engine compartment heat. I will show you my set up, its basically the same type of tubing with an elbo into the factory air box, with the bottom gutted out, sucking in cool air from under the engine blowing in from the front grill..... submariner409 10-23-08, 10:07 AM Many, many, many threads and posts in here and in Seville over the years concerning so-called Cold Air Intakes. Generally, they aren't and do nothing except sometimes insert a low-rpm stumble or midrange power loss. The increase in engine/air noise is perceived as a power gain, which is false.
Several of us have followed MSTA's idea and simply gone into the stock airbox and filter system (larger than a 279 c.i. engine needs, BTW), removed the U-tube which already goes outside the engine compartment, so the system is CAI to start with, and run a slightly larger duct down to just behind the lower grille.
Sure, the K&N looks trick and gives you some bragging rights, but it's really only eye-candy and can cause some real engine problems if you get carried away with the necessary cleaning and oiling (a little is good, so a lot must be better: NOT !)
Do some searching for Seville CAI threads and the butt plug. Use a WIX air filter (oil filter, too) because it has much more media surface area than the ACDelco or Fram units. Ask to see each one at an auto parts store......the difference is obvious. CadillacSTS2003 10-23-08, 12:19 PM :banghead: kevinscaddy01STS 10-23-08, 03:28 PM Many, many, many threads and posts in here and in Seville over the years concerning so-called Cold Air Intakes. Generally, they aren't and do nothing except sometimes insert a low-rpm stumble or midrange power loss. The increase in engine/air noise is perceived as a power gain, which is false.
YES!! will def slow it down...
Car looks sweet though.. msta293412 10-24-08, 10:46 AM Yes , on that note, your headlights are so damned clear! And on a 2000, I have a 2001, and theyr fogged up beyond recognition....Ive tried all the treatments ranging from, platic polish, to chemicals, etc, My lenses have millions of miniscule little cracks it them, I really need to just replace them but...$$$$$......Anyways, I digresse.... BSchorr 10-28-08, 06:52 PM Ha! Thats actually a new headlight there... The previous owner's grandson broke th headlight when he crashed into it with his bik handlbars. The other side dont look so pretty. But I will be buying this 3 stage headlight cleaning kit for it soon codewize 10-28-08, 11:24 PM The car already draws cold air so what's the point? Not to mention that the K&N filter elements are probably one of the worst at actually filtering.
Save the money and buy yourself a new pair of shoes, or a tricked out name tag. msta293412 10-29-08, 09:04 AM You WILL gain from the air box gut. Not because its not drawing cool air now, codewise is correct, but because with the air box gut, it will draw more air easier, thus giving you a bit of performance......especially when combined with some free flowing mufflers and and a slightly larger Y pipe.....BUT THAT IS IT, take my word for it, its easy to get carried away and go backwards..... stngh8r 10-29-08, 01:36 PM Dyno Results posted on Caddyinfo.com showed a +7whp and +4wtq peak and also notable power under the curve with a K&N drop in filter in a 4.0 baby*
Dyno Results showed +1-2whp and tq peak with a "modified" air box. But even better, the modified air box showed more improvement under the curve.
My interpretation: with a K&N drop in and modified air box you can expect roughly +10 hp.
The results that I reference are at this URL, unfortunately, the link has not been working for a couple of weeks. http://caddyinfo.onedgesolutions.com/dyno/4airboxtest.htm codewize 10-29-08, 05:32 PM 2 things here. What you're talking about it called air reserve. That only helps when you first mash the throttle. Nothing more. It will not increase HP.
The second problem with this statement is you can't get a larger Y pipe. Unless you know something about physics that the rest of us don't
You WILL gain from the air box gut. Not because its not drawing cool air now, codewise is correct, but because with the air box gut, it will draw more air easier, thus giving you a bit of performance......especially when combined with some free flowing mufflers and and a slightly larger Y pipe.....BUT THAT IS IT, take my word for it, its easy to get carried away and go backwards..... codewize 10-29-08, 05:33 PM I don't believe one word of this. You'll have to show us because we have substantial results showing otherwise.
The results that I reference are at this URL, unfortunately, the link has not been working for a couple of weeks. http://caddyinfo.onedgesolutions.com/dyno/4airboxtest.htm stngh8r 10-29-08, 07:23 PM It has been on the caddyinfo website for years, only lately has that particular link not been working.
On the same website there are also dyno results showing negative HP gains with a cone filter setup. codewize 10-30-08, 01:00 AM The factory intake setup, including the filter element is fully capable of flowing more volume than the N* can swallow at any RPM range so I'm not sure why or how someone could even suggest that a new air filter will add 10 horse power to a car. Maybe a Diesel truck, or a lower performance cruiser but not the N*
The N* system is not a typical car. It's already been engineered for performance. There is very very little, if anything to gain from this engine and you're not going to get it with a new air filter, I promise.
Show me the dyno sheets before and after and prove to me that the source is reliable. Additionally no conical style filter is going to loose HP. If anything you'll loose some low end torque due to decreased pressure / increased volume but the HP won't change.
In order to gain HP you need to flow more air. In order to flow more air you need larger intake plenum and larger exhaust. The intake we can all due and as mentioned above the factory setup is more the sufficient to begin with. On the other end we need larger exhaust which we already discussed can't happen. The only bottleneck in the N* air flow is the front to rear crossover which can't be changed.
If you change one without the other you will loose low end torque which we have also proven time and time again.
So again, unless you know something about physics that all the people here have overlooked, it's not happening. If you really want to show me something, show me time slips proving faster than stock times. stngh8r 10-31-08, 01:34 PM Codewize: I tend to agree with you, its hard to believe a cone filter would lose HP, maybe it was just sucking in alot of hot air? I simply wanted to share the information I had found, especially since it is about the only information I have found that actaully uses some form of testing besides the butt dynomometer (which seems to be the standard for quality around here, which has resulted in no mod being worth any HP apparently). My intention wasn't to start a debate on air filter theory or even argue about dyno results. As I have already stated, the dyno graphs have been on caddyinfo.com for years, feel free to read all about it. I assumed with over 5000 posts and having registered 3 years ago, you might have seen the aforementioned website and info already.
Eric codewize 10-31-08, 04:17 PM Yup, it's all good. I'm just shedding light on a topic that many people are very misled on.
I am a member over there actually I just don't have the time to frequent two forums :) | |
