: 2003 Escalade will not start
lander14
10-19-08, 07:46 PM
Hope someone here can lend some assistance/insight. I have a 2003 AWD Escalade that has recently decide to not start every now and then. I had a new battery and ignition swith installed 30 days ago. Worked fine until today - simply wil not start. When I turn the key everything lights up and the fuel pump starts as well but nothing fires. We ran a diagnostic and got the following codes:
U1041; B1440; U1000; U1016; U1041; U1096; U1064; c0045; C0050.
I have been researching this all day and have read that it could be a crank sensor?
Has anyone had this problem and been able to fix it?
Any help is much appreciated.
Thanks,
Nate
trodder
10-20-08, 11:15 AM
I thought I read somewhere that this is a known issue... I am wanting to say there may have even been a recall on it but I really don't know for sure... Hopefully someone can speak more intelligently on this.
lander14
10-20-08, 07:24 PM
I have looked and can't find any recall info on this issue. It did it to me again this morning. I had it towed to the dealer and of course it started when it got there. They ran another diagnostic but could not find anything wrong since the car started. Hopefully someone out there has the answer.... would really make my week :)
lander14
10-21-08, 10:35 PM
took my 03 to the dealer again today, ran another diagnostic and still nothing. They advised against replacingany sensors since they cannot pintpoint the issue. Would love to hear if anyone else found the solve to this problem. I have tried calling cadillac direct but of course no reponse!!!
lander14
10-23-08, 03:49 PM
So it wouldn't start again this morning. I pulled it into neutral to roll it back and before I let off the brake I decided to crank the key -- started right up. Dealer says it could be a sign that the park (?) sensor is bad and that could be the fix -- anyone ever heard of this before?
Thanks.
Lu Scola
10-23-08, 06:47 PM
That sounds like it could be the problem. Make sure there is a little green line under Park. You may have to mess around with the gear shifter to make sure its def in park.
lander14
10-24-08, 01:43 PM
Thanks Lu - I wil ldouble check that next time. I am taking it to the dealer again on Monday -- according to Cadillac it could also be an issue with the Tranny Linkage so they are going to run some diagnostics on it. I wil keep the post up to date as it sounds like others have experienced the problem -- It is my goal to find the fix so others can avoid all the costs and headache I am going through :)
Scott in Milwaukee
10-24-08, 02:09 PM
Try to start the truck in "neutral". That "connection" might be in better condition.
lander14
10-26-08, 09:17 PM
Thanks Scott. Any idea if the park sensor replacement is something that is wasy to do or is it something the dealer will have to do?
bstiffmanofsteel
10-26-08, 09:56 PM
I was on a road trip last year and my gfs car wouldn't start. Turned out not to be in Park. I can see it happening on occasion, but all the time... If it does it next time start it in neutral and see if that really is the problem. In my experience when the dealer starts tinkering around with your stuff, they'll mess up 2 or 3 more things... Good luck
lander14
10-27-08, 03:06 PM
Dealer finally (hopefully) found the problem -- the starter has a blown diode in it. Apparently that will no show up on any starter test and that is why they have not been able to locate it. For once the car did not start when it was at the dealer and that allowed them to run the right diagnostic and find the problem. $500 for the starter installed -- ouch but hopefully that wil llet me get another 75000 miles out of the car!!
bstiffmanofsteel
10-27-08, 04:51 PM
Goodluck man. Hopefully they have indeed corrected that issue.
Guyz1996deville
10-27-08, 06:14 PM
I had a situation wher intermittently my car would start back in the day. There was a faulting ignition module. little module in alternator and vwalla fixed:)
hcvone
10-29-08, 08:35 AM
If it only will start in neutral it could be the neutral safety switch, you can replace it but it may get a little messy
lander14
10-29-08, 01:57 PM
Thanks hc. It wouldn't even start in neutral the other day and that is when the dealer was able to locate the bad diode in the starter. I had it replaced on Monday and it is working fine - I actually notice a differenc in ease of starting so hopefully they in fact found the true problem. Between tows, new battery, new ignition switch and now the starter I have almost $1000 in to find and fix the problem -- if I get another 75000 out of the Escalade I will be more than happy :)
KamronZX6R
11-06-08, 09:40 PM
Opened this thread a little late. I had this issue in my 03. A few dealers checked it out couldn't find the problem. Local mechanic ran electrical tests to find the short, turns out a dime got in the lighter slot since i keep my change in the ashtray. I ran out and bought the male piece to the car lighter after that. Problem solved. Running the computer diag didn't help one bit.
Didewro
04-10-13, 06:05 PM
If the starter gets hot....would/could it become faulty?
wake
04-13-13, 02:13 AM
Interesting. I just posted my experience in the other 03 wont start thread and found this one.
Out of curiosity, did this condition also kill your battery at times? I replaced the starter on my truck and the problem never reoccurred. I was thinking a short in the starter or solenoid since I was also killing batteries.
