: help heat not working on 2000 escalade.
10-18-08, 05:16 PM
Hello all... My heat is blowing out cold air in my escalade.... Can someone please tell me what the problem is and how i can fix it.... And also how to locate the parts. Thanks in advance!
10-18-08, 09:03 PM
Im sorry its a 2002
10-19-08, 12:17 PM
its totaled....go buy a new one.
Devil Dog 00026
10-20-08, 01:16 AM
Could be a stuck Thermostat which doesn't allow the water (in the radiator) to heat up... or a bad heater core... make sure you don't have wet carpet on the passenger side... if you do it is probably the heater core... I have never changed a Escalade so can't be of much help... it is fairly easy if you can find the plastic housing under the dash that holds the heater core... open the housing (8 to 12 screws)... remove the two hoses from the core (under the hood on the passenger side)... I just don't know if you can get to the heater core housing under the dash... :hmm:
