: whats this?
odla
10-17-08, 10:49 AM
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 03/03/2004 18 miles 03/03/2008 50018 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/03/2004 18 miles 03/03/2010 100018 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/03/2004 18 miles 03/03/2012 80018 miles
48/50000 FEDERAL EMISSION 03/03/2004 18 miles 03/03/2008 50018 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
02/29/2008 409350 # N0760 - TAIL LAMP BULB REPLACEMENT 46360 miles
08/02/2007 387216 # Z7903 - 3-DAY COURTESY TRANSPORTATION 41824 miles
08/02/2007 387216 # J3100 - RADIATOR REPLACEMENT 41824 miles
08/02/2007 387216 # E7690 - SENSOR, STEERING WHEEL ROTATION - REPLACE 41824 miles
08/02/2007 387216 # N0110 - BATTERY REPLACEMENT 41824 miles
06/04/2007 381138 # N0761 - BULBS, STOP, TAIL, AND TURN LAMP (LEFT) - REPLACE 39065 miles
01/04/2007 J07289 # Z2085 - ROADSIDE SERVICE (PREMIUM) 37788 miles
12/28/2006 364448 # Z6720 - CADILLAC-COST OF TECH. TO MAKE ROADSIDE SRVC CALLS 37788 miles
12/28/2006 364448 # N0110 - BATTERY REPLACEMENT 37788 miles
03/16/2006 563953 # F3031 - BUSHING, REAR DIFFERENTIAL DAMPING - LEFT - REPLACE 25878 miles
03/16/2006 563953 # Z7903 - 3-DAY COURTESY TRANSPORTATION 25878 miles
03/16/2006 563953 # E3801 - SHOCK ABSORBER, FRONT - LEFT - REPLACE 25878 miles
02/10/2006 559496 # J3255 - CAP, COOLANT SURGE TANK PRESSURE - REPLACE 23609 miles
02/10/2006 559496 # Z7903 - 3-DAY COURTESY TRANSPORTATION 23609 miles
11/14/2005 547706 # N0110 - BATTERY REPLACEMENT 18787 miles
11/14/2005 547706 # Z7901 - 1-DAY COURTESY TRANSPORTATION 18787 miles
10/17/2005 544047 # N0100 - BATTERY - CHARGE AND TEST 17024 miles
10/17/2005 544047 # Z7902 - 2-DAY COURTESY TRANSPORTATION 17024 miles
09/01/2005 538297 # R5139 - ELECTRONIC NAVIGATION ANTENNA REPLACEMENT 15921 miles
*************Whats this*************
09/01/2005 538297 # R5140 - MODULE, VEHICLE INTERFACE UNIT VIU/VCIM - REPLACE 15921 miles
09/01/2005 538297 D R5139 - ELECTRONIC NAVIGATION ANTENNA REPLACEMENT 15921 miles
09/01/2005 538297 # Z7901 - 1-DAY COURTESY TRANSPORTATION 15921 miles
09/01/2005 538297 # V1302 - 05004 - REPLACE SDM 15921 miles
02/14/2005 144340 # V1233 - 04043 - INSPECT AND REPLACE BOTH LCA NUTS 11837 miles
02/14/2005 144340 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 11837 miles
02/14/2005 144340 # Z7410 - GOODWILL OIL CHANGE 11837 miles
06/03/2004 487288 # R9995 - CUSTOMER CONCERN NOT DUPLICATED 3178 miles
06/03/2004 487288 # Z7902 - 2-DAY COURTESY TRANSPORTATION 3178 miles
02/10/2004 A59246 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Merchandising Model : 6DN69 -2004 CTS-V
Gross Vehicle Weight Rating : 2182 kg (4811 lb) Order Number : GTRN3D
Build Date : 02/10/2004 Build Plant : 140D
OPTION CODES
AH8 - 10-WAY PWR. PASS. SEAT W/ PWR. LUMBAR AL2 - POWER LUMBAR CONTROL
AM9 - SPLIT-FOLDING REAR SEAT AQ9 - SEAT FRT BKT, LUXURY
AY0 - INFLATABLE RESTRAINT DRI & PASS A45 - MEMORY SEAT ADJUSTER
CE4 - WASHER HEADLAMP, HIGH PRESSURE CF5 - EXPRESS OPEN SUNROOF
CJ2 - HVAC FRT. AUTO TEMP/AUX TEMP DD8 - MIRROR AUTO DAY/NIGHT I/S R/V
DL5 - DECAL - ROADSIDE SERVICE INFO DR5 - MIRROR O/S REMOTE L/H R/H
E2C - RAPID DELIVERY SYSTEM FE4 - SUSPENSION
FE9 - 50-STATE EMISSIONS GT4 - AXLE REAR 3.73 RATIO
IL3 - TRIM INTERIOR DESIGN JJA - PT DRESS SUBASSEMBLY INSTALLED
J56 - BRAKES, ANTILOCK KA1 - HEATED FRONT SEATS
KG4 - 150 AMP GENERATOR LS6 - LS6 5.7L 400 HP V8 ENGINE
MN6 - TREMEC 6-SPEED MANUAL TRANS M12 - MANUAL TRANS
NT9 - EMISSION - FEDERAL N34 - STEERING WHEEL, LEATHER
PDL - LUXURY PACKAGE P32 - WHEEL 18" ALUMINUM
QKR - P245/45R18 ALL SEASON BW R8X - FLEET GUARANTEED DELIVERY PGRM
R9Z - POMS EXPEDITE-SOLD ORDERS/TSE SLL - SOLD ORDERS
TT6 - HIGH INTENSITY HEADLAMPS UAV - DVD NAVIGATION SYSTEM INCL: XM SATELLITE RADIO-100 CHANNEL COAST TO COAST DIGITAL SOUND (SUBSCRIPTION CHARGES EXTRA- DELETES COMPASS IN MIRROR)
UA6 - THEFT DETERENT SYSTEM UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1YR SAFE & SOUND PLAN
UG1 - UNIVERSAL GARAGE DOOR OPENER U2K - XM SATELLITE RADIO-100 CHANNELS OF GO ANYWHERE ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL
U30 - INSTRUMENT CLUSTER,TACH,CLOCK U57 - 8 SPEAKER SYSTEM
VM3 - LABEL-FRT & RR 5 MPH BUMPER V73 - VEHICLE STATEMENT USA/CANADA
1SA - CTS STANDARD PACKAGE 1SZ - PREFERRED EQUIPMENT SAVINGS
41U - BLACK RAVEN 6MH - COMP FRT LH COMPUTER SEL SUSP
7MH - COMP FRT RH COMPUTER SEL SUSP 70I - LIGHT NEUTRAL
703 - LIGHT NEUTRAL 8GW - SUSPENSION
9GW - SUSPENSION
do you see anything that should be out of the norm?
thanks guys
10-17-08, 12:50 PM
That's the Onstar module
That's the air bag module - It was a recall for inadvertent driver air bag deployment
Everything else looks pretty normal...
odla
10-17-08, 12:58 PM
cool thanks
CadiBlk
10-17-08, 01:11 PM
OMG that'd suck.
LUVMY04V
10-17-08, 02:04 PM
my car had that happen to the first owner too
CadiBlk
10-17-08, 02:11 PM
Was the driver side seat replaced? Cause mine would need to be for the brown stains on the suede. :canttalk:
