: E Brake Help
IceDigger
10-07-08, 05:40 PM
This is a weird problem. Sometimes I have to push down the ebrake 2 or 3 times to get the car to stay still on an incline. Any idea if this is a common problem and whats the fix?
Oh yea, I have an 05 V.
nikon
10-07-08, 05:41 PM
unlike older cars our park brake doesn't adjust itself...there's a write up in the faq I think.
SoJersey05V
10-07-08, 06:18 PM
mine used to go to the floor and still roll.... mind you my 05 has 34000mi and come to find out it was the e-brake shoes inside tho rear rotor hat... $97 each side.... OUCH! 34000mi? insane i have a 94 f150 i've never touched the e-brake and its got 130k on it!
bigREDfreshness
10-07-08, 06:18 PM
My park brake hasn't worked properly since the day I picked her up, and I wasn't about to drop the $400 that Cadillac quoted to fix it. Luckily LV is pretty flat...
perfect
10-07-08, 06:28 PM
occasionaly mine will do the same on an incline
i just press it a little harder and park it in gear
shadybx7
10-07-08, 08:23 PM
I have the same problem. Why wasn't it covered under warranty?
rjoffe
10-07-08, 09:11 PM
Mine was covered by warranty. It was just a simple adjustment according to the tech.
SoJersey05V
10-08-08, 11:02 AM
"normal wear and tear" i was pissed!
CadzillaTN
10-08-08, 02:58 PM
mine was junk when I bought the car w/28K miles... made a loud popping noise on the way down and would barely hold even at the floor. I can't imagine how anoyne could own the car in a place with steep hills. West TN is fairly flat so I don't need it often...
Dealer replaced the whole assembly under (factory) warranty. I am under the extended now and it isn't covered but technically still is, as anything repaired under warranty has a 12 month parts and labor guarantee that supercedes any warranty status. Im not sure if the replacement included the pads in the rear or not- I didn't ask. But, it felt awesome in the beginning, getting very tight only half way down or so. I am now having to push further to get a good "grab" but not to the floor, yet.....
