: Would you buy this V?
kimphamg
10-07-08, 01:10 AM
Hello, i was offered to trade my 05 3.6 CTS for a V plus some extra money.
Both car warranty ends in March/April 2009
Here's the service history on the V, parts of rear diff was changed a bit too often for my taste, should I be worried?
E9050 - POWER STEERING PUMP REPLACEMENT 50052 * *kilometres
J4100 - GENERATOR REPLACEMENT 50052 * *kilometres
N6602 - WIRING AND/OR CONNECTOR - CHARGING/STARTING/BATTERY - REPA 50052 * *kilometres
J1420 - FLYWHEEL (MANUAL TRANSMISSION) - REPLACE 49134 * *kilometres
F1610 - SEAL, AXLE SHAFT OIL - REAR AXLE - RIGHT - REPLACE 44300 * *kilometres
F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 44300 * *kilometres
E0722 - TIRE PRESSURE INDICATOR SENSOR REPLACEMENT 44292 * *kilometres
N0760 - TAIL LAMP BULB REPLACEMENT 44292 * *kilometres
Z8050 - MAINTENANCE (LUBE OIL FILTER) 44292 * *kilometres
H2505 - ELECTRONIC BRAKE AND TRACTION CONTROL MODULE REPLACEMENT 41775 * *kilometres
B1500 - HOOD AND/OR LATCH ASSEMBLY - ALIGN/ADJUST 38410 * *kilometres
F1610 - SEAL, AXLE SHAFT OIL - REAR AXLE - RIGHT - REPLACE 29491 * *kilometres
B7766 - MOLDING, ROCKER PANEL - REAR - RIGHT - R&R OR REPLACE 29490 * *kilometres
H0122 - FRONT BRAKE ROTOR REFINISHING 28402 * *kilometres
Z8050 - MAINTENANCE (LUBE OIL FILTER) 28402 * *kilometres
E4187 - INSULATOR AND/OR SUPPORT, REAR STABILIZER SHAFT - BOTH - R 26010 * *kilometres
F1617 - SEAL, AXLE SHAFT OIL - REAR AXLE - BOTH - REPLACE 26010 * *kilometres
F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 26010 * *kilometres
F9706 - INSTALL REAR DIFFERENTIAL HOSE AND VENT (CADILLAC) 26010 * *kilometres
Z7903 - 3-DAY COURTESY TRANSPORTATION 26010 * *kilometres
J3100 - RADIATOR REPLACEMENT 25025 * *kilometres
Z7903 - 3-DAY COURTESY TRANSPORTATION 25025 * *kilometres
Z8050 - MAINTENANCE (LUBE OIL FILTER) 25025 * *kilometres
Z8066 - SEMI-ANNUAL INSPECTION (CAD MAINTENANCE) 25025 * *kilometres
Z8050 - MAINTENANCE (LUBE OIL FILTER) 15383 * *kilometres
J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS 11598 * *kilometres
E3537 - LOWER CONTROL ARM REPLACEMENT - BOTH SIDES 11577 * *kilometres
E7650 - MODULE, IGNITION LOCK CYLINDER (HOUSING) - R&R OR REPLACE 11577 * *kilometres
Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 11577 * *kilometres
Z8050 - MAINTENANCE (LUBE OIL FILTER) 11577 * *kilometres
Z8051 - CAD MAINTENANCE (TIRE ROTATION ) 11577 * *kilometres
Z8050 - MAINTENANCE (LUBE OIL FILTER) 7420 * *kilometres
R4806 - MODULE, ON-STAR-RESET/REPROGRAM - FRENCH CANADIAN ONLY 5084 * *kilometres
Z6998 - PDI ADDS 11 * *kilometres
Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
stuckey
10-07-08, 01:14 AM
how much extra money and how many miles left on the warranty err....kilometers
tophat02
10-07-08, 01:16 AM
Well look on the plus side: the prev owner(s) obviously cared enough to take it in for regular service! :thumbsup:
kimphamg
10-07-08, 01:29 AM
There's about 20,000 miles left on the warranty (or less than 6 months) and he's selling it to me for 26.5K$US with 4 winter tires and free oil change for life... remember that i'm in Canada so everything is more expensive. He is basically buying my CTS for 16K$US (3.6 + NAV + full equip with 45k miles on it).
Any comments on the service history?
kimphamg
10-07-08, 01:33 AM
There's about 20,000 miles left on the warranty (or less than 6 months) and he's selling it to me for 26.5K with 4 winter tires and free oil change for life... remember that i'm in Canada so everything is more expensive. He is basically buying my CTS for 16K (3.6 + NAV + full equip with 45k miles on it).
Also please note , it is the dealership that is trading my CTS, not a private owner.
rand49er
10-07-08, 07:36 AM
Don't see much on that service history that shocks me (with the mild exception of the power steering pump) nor anything that would deter me from buying the car. I agree with the above comment that it seems like someone was quite vigilant about getting things taken care of.
With a decent chunk of warranty left, you should be able to take care of anything that's been overlooked.
Since it's a dealership, is there any chance you can get them to throw in a set of FG2 shocks?
odla
10-07-08, 07:59 AM
i would plop down a little more money or negotiate a warranty for at least an extra year.
tdyguy2k
10-07-08, 09:48 AM
Or if it's a Cadillac dealer, get it certified.
kimphamg
10-07-08, 10:02 AM
Wow, great response from the members, i like it!
My CTS also had its power steering pump changed, and it seems many CTS/CTS-V have a failing power steering pump at around 50k miles.
The car comes stock with FG2 shocks :highfive:
I will try to bargain an extended warranty, i'll let you guys know how it goes.
CTSV_510
10-07-08, 10:24 AM
I'd take it. FG2s are a big plus, and if you can get an extended warranty out of it (usually easy to bargain), then I'd say you're about to make the best decision in your life upgrading to a V...
:woot2:
NIK
10-07-08, 02:13 PM
My '05 V's power steering pump went out at 24,000 miles - I had just left my factory 48 month warranty one month before (car was put into service June 8, 2004.)
My GMPP extended warranty took care of everything including a car rental because the pump had to be ordered. It's the only problem I've had since I purchased it new and the pump went out very suddenly - no whining, no warnong what-so-ever. It came as a total shock to me.
