: which tranny?
seanandniksts4
10-06-08, 05:00 PM
this is a dumb question but I dont know which tranny i have, this is the VIN info;
VIN # 1G6DW677060178606
2006 STS V6 LUXURY SPORTS SEDAN
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 03/07/2006 15 miles 03/07/2010 50015 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/07/2006 15 miles 03/07/2012 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/07/2006 15 miles 03/07/2014 80015 miles
48/50000 FEDERAL EMISSION 03/07/2006 15 miles 03/07/2010 50015 miles
72/100000 LUXURY CERTIFIED PRE-OWNED LIMITED WARRANTY 03/07/2006 15 miles 03/07/2012 100015 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
08/15/2008 171712 # F2142 - DIFFERENTIAL CARRIER ASSEMBLY REPLACEMENT 37265 miles
08/15/2008 171712 # Z7903 - 3-DAY COURTESY TRANSPORTATION 37265 miles
08/15/2008 171712 # C6870 - COVER AND/OR PAD, FRONT SEAT CUSHION - RIGHT - R&R OR REPL 37265 miles
07/02/2008 170145 # V1798 - 07204 - REPLACE FRONT AND REAR DIFFERENTIAL SEAL (SRX AWD, 36305 miles
06/23/2008 156499 # C2200 - INSTRUMENT PANEL ASHTRAY REPLACEMENT 36080 miles
02/13/2007 263587 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 16497 miles
02/13/2007 263587 # Z7902 - 2-DAY COURTESY TRANSPORTATION 16497 miles
02/13/2007 263587 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 16497 miles
11/14/2006 259380 # D2109 - HEATER/AIR DISTRIBUTION CASE, PASSENGER COMPARTMENT (AIR C 12048 miles
01/27/2006 A78606 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
1SC - 1SC LUXURY PERFORMANCE PACKAGE: *MULTI-DRIVER MEMORY SETTINGS *POWER ADJUSTABLE LUMBAR *HEATED/VENTILATED FRONT SEATS *HEATED REAR OUTBOARD SEATS *HEATED, WOOD STEERING WHEEL *EUCALYPTUS WOOD TRIM ON CENTER STACK, CONSOLE, IP, SHIFT KNOB, DOOR TRIM AND STRG WHEEL *BOSE 5.1 STUDIO SURROUND SOUND WITH IN-DASH 6 DISC DVD CHANGER AND ADVANCED DVD NAVIGATION *RAINSENSE WIPERS *UNIVERSAL HOME REMOTE *AUTO DIMMING ISRV MIRROR (REPLACES STD ISRV MIRROR) *17" POLISHED ALUMINUM WHEELS *TIRE PRESSURE MONITOR *EXPRESS OPEN/CLOSE SUNROOF *REAR SPOILER *TRUNK CONVENIENCE NET *AUTO AIR QUALITY SENSOR PERFORMANCE FEATURES: *LIMITED SLIP DIFFERENTIAL (N/A WITH ALL WHEEL DRIVE) *4-WHL. PERFORMANCE DISC BRAKES WITH ABS *PERFORMANCE COOLING PACKAGE
1SZ - PREFERRED EQUIPMENT SAVINGS
25U - BLUE CHIP
322 - CASHMERE
32I - INT TRIM MED DK CASHMERE
6DB - SUSPENSION
7DB - SUSPENSION
8HC - COMPONENT SUSPENSION
9HC - COMPONENT SUSPENSION
A45 - MULTI-DRIVER MEMORY SETTINGS
AL2 - POWER LUMBAR CONTROL
AP9 - TRUNK CONVENIENCE NET
AQ9 - SEAT FRT BKT, LUXURY
AY0 - INFLATABLE RESTRAINT DRI & PASS
B20 - EUCALYPTUS WOOD TRIM ON CENTER STACK, CONSOLE,IP, SHIFT KNOB, DOOR TRIM AND STRG WHEEL
CE1 - RAINSENSE WIPERS
CF5 - EXPRESS OPEN/CLOSE SUNROOF
CJ2 - HVAC FRT. AUTO TEMP/AUX TEMP
DD8
DL5 - DECAL - ROADSIDE SERVICE INFO
DR2 - O/S REARVIEW PWR, HEATED MIRRS
FE1 - INDEPEN SUSP W/AUTO REAR LEVEL
FE9 - 50-STATE EMISSIONS
GU5 - AXLE REAR, 3.23 RATIO
IL2 - TRIM INTERIOR DESIGN
JE5 - 17" PERFORMANCE BRAKES
JJA - PT DRESS SUBASSEMBLY INSTALLED
K14 - FILTER, AIR, AUTO RECIRCULATING
KA6 - HEATED SEATS, REAR
KB6 - HEATED/VENTILATED FRONT SEATS
KG4 - 150 AMP GENERATOR
LY7 - 3.6L V6 VVT ENGINE 255 HP
MX5 - ALL WHEEL DRIVE W/MICHELIN S-RATED P235/50R17 TIRES (REPLACES STANDARD TIRES) (INCLUDES CREDIT FOR DELETED SPOILER, PREMIUM ZF STEERING GEAR AND PERFORMANCE COOLING)
MX7 - MERCH. TRANS
N31 - HEATED, WOOD STEERING WHEEL
N93 - 17" POLISHED ALUMINUM WHEELS
NT7 - EMISSION - FEDERAL
QKP - P235/50R17 MICHELIN S-RATED
R6M - NEW JERSEY COST SURCHARGE
R6P - PREMIUM PAINT
R8K - *******************************
R9N - LEATHER
SLM - STOCK ORDERS
T84 - HEADLAMPS RH RULE OF THE ROAD
U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
U30 - INSTRUMENT CLUSTER,TACH,CLOCK
UA6 - THEFT-DETERRENT ALARM SYSTEM
UE1 - ONSTAR SYSTEM INCLUDES 1 YR DIRECTIONS & CONNECTIONS
UG1 - UNIVERSAL HOME REMOTE
UJ6 - TIRE PRESSURE MONITOR
UY5 - 15 SPEAKER SYSTEM
V73 - VEHICLE STATEMENT USA/CANADA
C&C
10-07-08, 06:10 AM
I can't be exactly sure but I believe the V-6 got the 5L40-E and the V-8 got the 5L50-E transmissions; don't know which the AWD model got.
Regulator
10-07-08, 12:09 PM
How did you pull all of that information on your car? If I gave you a vin, could you do the same for me?
BaTu
10-07-08, 12:58 PM
Regulator - If you're a "Supporting Member" (notice the ID under Sean's name and mine....) you can go to the CTS-V 04-07 forum here and request a "VIN Check" under it's Sticky :)
Another member will get you all the Factory Service records and info about your car! (really worth it to support the board as well)
Cliff8928
10-07-08, 02:07 PM
Your transmission code is "MX7" which just has a generic description of automatic for AWD
