: PAC swi jack eldorado
09-29-08, 08:22 PM
PAC swi jack eldorado if i get one of these units can i control my aftermarket radio with it or is in the the class 2 data wire? and if it will work with my 97 eldorado does anyone know what wire i would use because if i look at the website it says hook there green wire up to my dark blue or light green wire, and i dont understand, thanks for your help
09-30-08, 04:04 AM
It should be a dark blue wire. You'd have to tap into it between the column and the IPC (gauge cluster)
09-30-08, 10:23 AM
ok thank you when i get home from work tonight i will try that
