View Full Version : 04 Deville want to use OEM XM antenna for aftermarket Sirius
MrCloudz
09-12-08, 03:58 PM
Where is the Xm tuner located? Do I need the
-XM to SIRIUS Dual Input Antenna Adapter
or
-XM to SIRIUS Single Input Antenna Adapter
Thanks!
Cliff8928
09-13-08, 02:24 AM
what antenna do you have?
The XM Receiver is on the drivers side in the trunk behind the trim panel attached to the reinforcement panel. You can see the two bolts holding it in going through the reinforcement panel.
MrCloudz
09-13-08, 10:43 AM
OEM sharkfin xm antenna. I'm going to go take a look now. I plan to remove the xm tuner and replace it with a pioneer sirius tuner, retaining the oem antenna. Main reason for this is that I hate the sirius micro dot antennas. I went through 4 of them in my grand cherokee (no pinching).
Cliff8928
09-14-08, 03:05 AM
Shark fin? It's kinda vague seeing as GM has used no fewer than 5 different antennas over the years.. Some have 2 leads, some have one. Depends on which one it is.
MrCloudz
09-17-08, 09:46 PM
btw I looked and it's a dual antenna tuner, so I ordered "XM to SIRIUS Dual Input Antenna Adapter" I will let you guys know how it works out.
besjr69
04-07-11, 11:47 PM
McCloudz,
Just wondering if this ever worked. I have an '05 with an aftermarket radio, amplifier bypass. I would like to add Satellite Radio, but want to use the OEM antenna instead of the magnet mount.
Bobby
