: Dyno Run
CadillacSTS42005
09-08-08, 10:13 PM
Well technically its a Dynolicious Run...
I downloaded the new app to try on Niks ipod touch that i bought her after raving reviews about how accurate it is.
Well on the way to school i was able to get 2 good runs in and heres how the 03 STS with Corsa & K&N Panel Filter stacked up
Weather Clear Night
Outside Temp 80 Degs
Info on Car that is inputted:
Weight 4200 lbs with driver
Drivetrain Loss 25%
These are the results according to the Ipod for the runs
Results of an Average of the 2 Runs
0-10 .92 secs
0-20 1.86 secs
0-30 2.94 secs
0-40 3.97 secs
0-50 5.21 secs
0-60 6.76 secs
0-70 7.79 secs
0-80 9.40 secs
Elapsed Time:
60' 2.65 secs @ 25.8 MPH
330' 6.66 sec @ 57.8 MPH
1/8 9.62 sec @ 79.2 MPH
1000' 12.24 sec @ 93.1 MPH
1/4 14.59 sec @ 88.6 MPH
Miscellaneous:
Max Speed 81.5 MPH
Max Acceleration .87 G's
Peak HP 243 HP
NHRATA01
09-08-08, 10:49 PM
I'd heard about that program, never tried it.
The drag times look somewhat inaccurate. A 2.65 60' is horrific, I bet taking it easy you should easily get a 2.3, and with a decent hook on a good surface and skilled throttle modulation, a 2.2 or 2.1 shouldn't be out of the question. And IMHO the MPH on the 1/4 time is probably about 4-5mph too low for that ET on a FWD car...especially if the 60' was that poor.
CadillacSTS42005
09-08-08, 11:34 PM
for what it is a 14 dollar app id say its a decent indicator to say the least
again though it was the average of two runs one of which i had a hugely hard time hooking up (sucks on gravel roads) so that likely skewed them a bit
i suppose i should post individual results for each run maybe?
RodneyPierce
09-08-08, 11:36 PM
ive got to disagree on one small subject. the worse the short time usually means more mph. If you have a shitty short time then you have more time to build MPH.
NHRATA01
09-09-08, 11:16 AM
That was what I was implying in my post. The MPH on the trap is too low, even with a decent 60'. Would be even higher on a bad 60'.
Raze
09-11-08, 02:25 PM
Thread title misleading, Dyno run is not equal to Accelorometer run, but it's cool you can use your Ipod Touch as a G-Tach...
ejguillot
09-11-08, 07:04 PM
Apparently it's better than a G-Tech. The guys at Garage419 think so, after their testing:
0-DFbJQbeSY
Plus in the video they show that the Dynolicious software's HP estimate was within 5HP of the dyno run they did.
Raze
09-11-08, 10:09 PM
accelerometer's readings are only as 'accurate' as the inputs you provide, if Jay weighed his car with himself and fluids and whatever other material in there, and knew for sure what the drive line loss is, assuming the HP rating is accurate, most dyno runs of N*s have shown a trans loss anywhere from 25% to as much as 30% it just depends case to case. I'm not doubting, just saying there's a lot of potential inaccuracies and claiming this is as a 'dyno' run is misleading...
CadillacSTS42005
09-12-08, 12:14 AM
factory weight is 3996 LBS
i figured with me half tank tools etc im pushing 4350-4400 lbs
i was told by the makers when i contacted them if i leave the dt % clear ill get wheel HP
weight and % loss are the only inputs
today was a really shyty run and i got a 7.08 0-60 and a 15.02 1/4.
BlackCaddy87
09-14-08, 02:03 PM
why would your 1/4 be a lower trap speed compared to your 1000ft?
msta293412
09-15-08, 09:51 AM
yea, I call BS.
BlackCaddy87
09-15-08, 12:15 PM
maybe he just let off too early
CadillacSTS42005
09-17-08, 10:06 PM
because its an average...
try reading the whole thing before raising the BS flag...
BlackCaddy87
09-18-08, 10:17 AM
does it tell you when you've completed the 1/4 mile?
CadillacSTS42005
09-19-08, 12:25 AM
emits a beep with to be honest is rather hard to hear over the Corsa at WOT
