View Full Version : Tires
Mackenzie
06-10-03, 10:48 PM
Our 76 Calais calls for 235-75 R15 tires. We have a chance to pick a bargain pair of 225-70 R15. Does anyone know if there is any problem putting these on the car?
Thanks in advance,
Bob
catbert
06-20-03, 10:33 PM
Thanks in advance,
Bob
Rule of thumb - never go down in size, but to make sure, check the load rating of the specific tire.
Katshot
06-21-03, 07:53 AM
Anytime you want to change tire size, I would suggest going to http://www.tirerack.com
and checking the tire dimensions first. Off the top of my mind, I would say that your tire choice should be fine but remember that the 70's will be a little lower (smaller diameter) , but wider, so the wheel wells will seem even LESS filled-up with the 70's.
I used to do the "75-series" to "70-series" swap on ALL my cars but I also made sure to "fill them wheel wells" by staying with the same (or larger) first number. (example: stay with the 235's and don't drop to a 225)
Mackenzie
06-26-03, 03:46 PM
Thanks guys. Just so I am clear...if we drop from 235/75/15 to 235/70/15 this will work fine...in otherwords, will it effect the ride, safety or tread life.
Thanks,
Bob
Katshot
06-26-03, 04:38 PM
Thanks,
Bob
That depends more on the tire type, and manufacturer than the size (especially only changing just one size).
The size change will provide you with a slightly lower profile, but slightly wider tire. Generally this slight size change will not give you a problem. All things being equal, the ride MAY end up being slightly firmer with the added benefit of better handling.
Elvis
06-26-03, 05:23 PM
NEVER drop a size with that first number. Dropping a size with the second number might give you a rougher ride.
HotRodSaint
06-26-03, 05:55 PM
If it's a deal, go ahead and do it.
And here's two great tire sizing sites to help with these questions.
http://amsoft.ru/tiresize/index.html
http://www.geocities.com/xtremephoenix/tire.htm
Mackenzie
06-26-03, 06:45 PM
Thank you Kevin, I appreciate your advice.
Bob
Katshot
06-26-03, 07:26 PM
Nice sites :thumbsup:
