: Trunk Pull Down Mechanism - $7 FIX
jey
09-02-08, 12:17 AM
Went to the junkyard today to find a replacement pull-down mechanism for the 93 Fleetwood (the motor the pulls the trunk shut after you close it).
Someone had already gotten to the one Fleetwood that was there.
Then I remembered reading on an older thread here that the mechanism for the LINCOLN TOWN CAR is the same. Well there were like a dozen Town Cars there, so I looked.
Turns out it is a DIRECT SWAP - bolt points, wiring harness, everything. Pick and Pull was having a 50% off sale this weekend. $7.17 later (though I had to buy a T27 TORX BIT to get the Fleetwood one removed!) I have working pull-down mechanism again.
Now the headache of dismantling it and winding it down by hand which somehow stripped the worm gears is all past.
pompste
09-02-08, 09:36 PM
Good for you! Who would have thought a Lincoln and a Fleetwood would share the same trunk motor pulldown?
My_favorite_Brougham
09-03-08, 02:37 AM
3rd party vendor to both, maybe? I doubt one would buy from another.
cadillac_al
09-03-08, 12:18 PM
Good tip, now I can expand my search. I need one for my 77 Fleetwood. It looks a little different than others I've had but I haven't removed it yet to examine it closely.
jey
09-03-08, 01:28 PM
Holy cow, the 77 Fleetwood had the pull-down latch too? That would be something if they used the same mechanism for almost 20 years. The one I'm dealing with has a 5-pin wiring harness, and bolts onto the trunk latch bracket with 3 bolts/screws. It looks like what Cadillac/Lincoln did was take the 3rd party trunk latch, and build an adapter bracket for their respective car that would ultimately bolt the latch to the car.
75sled
09-03-08, 01:53 PM
I had a 65 deville with a trunk pull down. I don't think it was the same sort of mechanism as what was used in the 70s or even today, but it was a truck pull down none the less.
Cadillacboy
09-04-08, 11:36 AM
WOW , 60's Caddies had had trunk pull down too , that's amazing Cadillac really make difference
scurling
09-06-08, 01:41 PM
Thanks for the good info. Eventually, we may all need a good cheap replacement. I think you should go back and buy the other trunk pull down units and sell them out on eBay. I'd give you $30.00 for your efforts. :-)
jayoldschool
09-06-08, 02:53 PM
Hmmm...
This makes me want to start a "Tech Tips" sticky for this section. What do you guys think? I'll PM Urb and see what he thinks...
scurling
09-06-08, 11:46 PM
That would be great with key words on the entries to assist with future searches. PN entries when possible and where applicable to assist with cross reference look ups.
I never would have though a Ford of Lincoln trunk latch part would would on the GM.
AladdinSane5150
09-07-08, 12:33 AM
Hmmm...
I think that's an OUTSTANDING idea, Jay! I just got my shop manual off of e-bay (mint, btw) and it covers alot. However, it would be good to know model/year interchange info. for those junkyard hunting trips.
N0DIH
09-07-08, 11:36 PM
I have to get to a boneyard, mine isn't stripped gears, it is the switch that tells it to start/stop that broke.... Gears ok....
