: Doing my own head gasket
BradH
08-22-08, 12:36 AM
My 2000 SLS started overheating so I checked the coolant for cumbustion gasses. It failed the test so I went ahead and bit the bullet and pulled the engine and trans. I got the heads off tonight and the gaskets were trashed between the cylinder and outer block. I'm thinking of going the Norm's insert/Cometic MLS route. I've also got a P1860 and P0741 so I will put in a TCC solonoid while it's all out. I followed some of the threads on here that were very helpful along with the factory service manual I purchased. I dropped the cradle out the bottom by supporting it on jackstands while I lifted the car with a cherry picker as suggested in another thread. Worked perfect! A 37 Ford axle slid under the bumper mounts did the trick. Once the body was up I used 2 floor jacks to lift the cradle and set it down on dollies so I could roll it out the side.
AJxtcman
08-22-08, 08:26 PM
Why would you replace your head gsk's?
I would give you a fresh engine for the car on the left!
We could work out a deal on a fresh trans also. It is also built and sitting, but is a performance trans. I could switch it back very easy
EVERYTING MUST GO MOVING SALE!
BTW 64 or 65?
I am old and can't tell any more
BradH
08-23-08, 12:36 AM
I've already got parts on order so I'm comitted to battle on this project. The car on the left is a 64 Riviera with factory 2x4 barrel 425 nailhead. Nice eye!
BTW 64 or 65?
zonie77
08-24-08, 01:23 PM
Nice trio of cars.
BradH
10-20-08, 12:36 AM
It's done finally. I ended up spending a month in Louisiana for hurricane season right after I got the engine out so it set me back a little. The head gaskets were difficult but not impossible. It's the time it takes to do it all that makes it difficult. I used a fel-pro gasket set and head bolts along with norms insert kit. I followed Norm's instructions and it worked perfect. I replaced the TCC solenoid while I had the engine/trans out. I had P0741 and P1860. It was a cheap and easy fix and now the converter locks up. Hopefully I can go back to working on iron V-8s with one camshaft for fun now!
801Hill
10-20-08, 01:19 AM
Great job! thanks, it gives me motivation working on mine. Ive got the engine out but I havent started the teardown yet. I'm ready to go back to old iron V8s too, anything will be easy after this job.
Playdrv4me
10-20-08, 03:20 AM
That is the understatement of the century! Good luck and keep us posted on your progress.
