View Full Version : Aftermarket Fuel Pump?
2003RC51
08-01-08, 06:39 PM
I'm not changing the pump yet, but I am kinda curious what pumps we have. Will a walboro 340 bolt up or do we have something completely different. I looked through the FAQ and searched on here but could not come up with much.
Thanks.
RGRATTAN
08-01-08, 07:10 PM
Nope...
Well it'll work for a couple hours until it burns out.
The 340 is a 255LPH pump designed for a return style fuel system unfortunately the V has a returnless system so it is not compatible.
rand49er
08-01-08, 08:05 PM
Whuddaya need a bigger one for?
Got FI?
EDIT: Guess I was a little presumptuous that you needed a "bigger" one. Oops!
2003RC51
08-02-08, 09:35 AM
Just have some mods in the works. I just don't want to run out of fuel when i get to where i am going.
So what fuel pumps are out there for us? I just want an in tank setup, and if some fab work is required its not a problem.
rand49er
08-02-08, 10:23 AM
Stock fuel pump here with no Magnavolt (boost-a-pump) with 60 lb/hr injectors. I am absolutely at the limit of the stock fuel pump (fuel pressure was down to 30 psi at about 6400 RPM on the dyno and A/F was going above 12:1). I'm thinking of a 2.6" pulley but can't do it unless I'm willing to install a Magnavolt (:annoyed:) or go to an aftermarket fuel pump.
What mods are you contemplating?
v-sam
08-02-08, 11:02 AM
It would be nice to have one that works better on the track...
NormV
08-02-08, 02:46 PM
That would use some major baffling. Not something you could retrofit. Besides you'd loose capacity.
Norm
2003RC51
08-02-08, 03:00 PM
Right now I have:
Kooks 1 7/8 Headers
No Cats
B&B Exhaust w' X-Pipe
CAI
Next month:
Nitrous
Tune
I have EFI Live and the nitrous setup, I'm just waiting on some fittings before I can install them. Cam should be shortly after that.
Couple more months:
Intake
TB
Cam
Re-Tune
ctsv154
08-02-08, 03:55 PM
Stock pump will more than handle what you have listed. Unless you are going F/I than I wouldn't worry about pump. Good injectors will handle anything you have listed and more.
rand49er
08-02-08, 05:17 PM
Stock pump will more than handle what you have listed. Unless you are going F/I than I wouldn't worry about pump. Good injectors will handle anything you have listed and more.Not sure about nitrous, myself. What if he put in a $hitload of nitrous (e.g. a 200 shot)? Wouldn't he need a heap more fuel to keep A/F reasonable (11:1 to 12:1 range) and possibly run out of the fuel the stock pump provides? I'd think anything from about a 150 shot and lower he'd be okay.
(I REALLY don't know to be perfectly honest. Just trying to understand it better myself.)
ctsv154
08-02-08, 07:37 PM
Well personally I wouldn't go over 150 on a stock bottom end and with our pistons. He never said he was going to do any internal work other than cam so thats kinda what I went by. But yeah a 200 shot would require more fuel but I'm not much of a nitrous guy so I cant tell you if the stocker could do it or not. But to run a 200 shot reliably he would also need a well built bottom end.
rand49er
08-02-08, 09:10 PM
^^ Yup.
1badjimmy
08-02-08, 09:45 PM
Nope...
I believe the V has a return style fuel system. If you look at the fuel filter there are two lines on the feed side. One of those lines is the return because the filter has a pressure regulator inside of it. To me it looks very similar to the C5/6 vette filter. A lot of guys swapping in LSx motors into S-10s use that filter because the fuel rail only has an inlet.
2003RC51
08-03-08, 10:30 AM
I will be starting with a 100 and eventually making my way up to 200 and possibly a 250. As long as you use the nitrous correctly and safely I dont see it hurting the bottom end immediately. A new engine is inevitable for me anyways, i just want to see what it will do up to that point. I have the FJO controller so I am going to ramp up the nitrous very gently and not shock the engine or rear too much and I will also be running a c10 mix most the time.
I will basically be running 125 around the street and only use the 200-250 on rare occasions.
On a side note I have seen some LS1 cars on 350 worth of nitrous using stock bottom ends. Is it reliable no, but what the hell.
rand49er
08-03-08, 01:26 PM
Looking into my crystal ball, I see a new diff in your future.
2003RC51
08-03-08, 02:08 PM
I figure its probably about my time for a new rear anyways. I have about 42000 "spirited" miles on this one and still no whine. The fluid hasn't even been changed in it. Figure if I did change it, thats when it would let go.
RGRATTAN
08-04-08, 02:20 PM
If this was the case I would be excited but unfortunately it is just not so.
You are right in saying that the filter has a return in it but is not a fuel pressure regulator by any means.
CTS-V = Returnless system as in almost every car on the market since early 2000.
Not sure how the intake setup is in the V but theoretically you could use two of the stock V pumps. A tune would obviously be absolutely mandatory since two pumps with the stock voltage would be a lot of fuel but I think it could be done.
This would be a good question for the StealthV and if he could tune around this.
