: Survey time: 40psi Oil Pressure at Idle?
The Tony Show
07-31-08, 01:06 PM
I searched around but couldn't find this discussed anywhere.
I never really paid attention to my oil pressure (normally I keep the display set to oil temperature), but noticed recently that the oil pressure hovers around 40psi at idle.
That seems kind of high to me, so I checked the shop manual- it lists the minimum pressure as 6psi @ 1,000 rpm, 18 @ 2,000 and 24 @ 4,000. I'm running the stock oil pump and no aftermarket accessories or pullies that could be overdriving it, so I'm a little stumped.
If any fellow owners could chime in with their idle reading, I'd appreciate it.
darkman
07-31-08, 01:27 PM
44 Psi here, at idle - motor cold.
Twitch
07-31-08, 01:34 PM
Seems about right. At start up, its near 60psi, then goes down.
The Tony Show
07-31-08, 01:42 PM
Ah, good. There's no MAX specification in the Shop Manual, and 8x the minimum seemed excessive.
Thanks for checking, Twitch and Darkman.
atdeneve
07-31-08, 01:59 PM
Yeah, in the 40s is what I recall.
CTSV_510
07-31-08, 02:54 PM
I think mine is around 37-38 at idle.
nikon
07-31-08, 03:45 PM
:( mines at 35-40 under power.......
Tmac11
07-31-08, 06:02 PM
40-42 at idle when cold and 29-30 at idle when everything heats up to normal temp.
SkullV
07-31-08, 09:50 PM
You better get that checked out!
razl
08-01-08, 11:18 AM
So mine's ('06) at 40'ish at cold idle, but now you've got me worried because when I watch it during driving, it's up around 70-80 at 4-5kRPMs. Since it looks like the gauge only goes up to 100 (no top number shown, but that's what it looks like) I'm concerned that the 70-80 is way high. Also, it looks like it will keep climbing right to the top if I go above 5k.
Suddenly I'm driving like a grandma scared to take it over 4k. I know Tony said the shop manual shows no Max, but that gauge makes it look like it's a bad thing to get it up around the top end (as in "we're only measuring to this point. If you're over it, well - good luck!").
So, new question for the thread - what's your oil pressure up around 6k+? :helpless:
darkman
08-01-08, 11:25 AM
Try this:
http://www.international-auto.com/fiat-lancia-tips-on-reading-gauges/tips-on-reading-gauges-oil-pressure-gauges.cfm
HushH
08-01-08, 12:26 PM
35 at idle here and i don't think i've ever seen over high 60s.
rdjiv
08-01-08, 05:29 PM
after a cold start, mine runs higher than the warm idle. from a cold start its around 40-45 psi. once it heats up, the idle pressure drops to 32-34psi.
Twitch
08-02-08, 07:53 AM
On my way home last night, I only got it up to about 5700. It was 67psi. After warm up it idles in the high 30s.
I'm running Mobile 1, 5w30. Dunno if the oil makes a difference. How about temperature? With my POS tuner, my temps are around 200 (usually 220-230).
Tony
Twitch
08-02-08, 07:55 AM
Try this:
Where you been hiding, D?
rand49er
08-02-08, 06:07 PM
Had a chance to drive the V today ... went to Lowe's. :D Never got above 2k RPM and got no cold readings.
Ambient temp = 78 deg F
First drive on fresh 6 qts of 5W-30 Mobil 1, new Fram TG-3506 filter.
Mileage = 41,787 miles
Readings (warm):
32-33 psi @ ~800 RPM (idle) with oil temp = 195 deg F
44 psi @ ~2,000 RPM with oil temp = 201 deg F
Seems to me that 40 psi at idle, if that was when the car is warm, is a bit high. If that was cold, then it would seem just right ... to me, anyway.
darkman
08-02-08, 06:41 PM
I've been lurking. Since I retired I have been spending less time on the computer and more time riding by motorcycle and shooting skeet.
tedcmiller
08-03-08, 11:30 PM
My 2005 CTS-V shows 42 psi at idle and cold engine. Pressure goes to 50 psi at 2k RPM, still with cold engine.
tedcmiller
08-04-08, 09:10 AM
This is my final report. After about 12 miles of continuous driving, some at 75-80 MPH on the Interstate, the oil pressure dropped (as expected) from 42 psi at cold idle to 32 psi at hot idle with oil temp at 205 degrees F and water temp at 197 degrees F. This is with Mobil 1 engine oil.
Twitch
08-04-08, 09:55 AM
I gotta get back to the range, never did skeet though.
